18 Inch Rims
Old Mar 12, 2025 | 12:00 AM
lauwrence.gl450's Avatar
GL450
Cool 18 Inch Rims
Hello, I'm wondering if 18 inch rims will fit my on 2007 GL450. I'm looking to build a overlanding build similar to those Porsche Cayenne's. Thank you very much.
Old Mar 12, 2025 | 08:43 AM
DennisG01's Avatar
'08 GL 320 CDI
Offhand, I don't know... but how much clearance do you have between the brakes and the rim with your current wheels? That should tell you.
Old Mar 12, 2025 | 09:09 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Yes they will, in fact they were original equipment. I am of course speaking of the MB OEM 18 inch wheels, with aftermarket wheels your luck may vary, depending upon offset width, center bore etc…
Old Mar 12, 2025 | 01:46 PM
lkchris's Avatar
'10 CL550, '12 GL550
You can probably find some on eBay. The tire size should be 265/60-18
https://www.alloywheelsdirect.net/me...00011950008269
Old Mar 12, 2025 | 02:34 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Did someone somewhere say that 17 inch rims from the ML also fit?
Old Mar 18, 2025 | 10:53 PM
alive19's Avatar
GL320 2007
They do, if you don't have the upgrade brake package.
The GLs in AU that came with 19" have a larger caliper and will not fit the 18" rim. I know this as I have changed my rotors and calipers to fit the 18" rim.
Old Mar 19, 2025 | 01:40 AM
GL450
If you don't mind me asking, how big is the rotors that you have currently? Can you measure and take a picture of it? To ensure accuracy. Thank you!
Old Mar 19, 2025 | 05:39 PM
alive19's Avatar
GL320 2007
Upgraded brakes have a 375mm rotor. The caliper is also different and will not fit the factor 18" rim.
Regular rotor is 350mm, and this fits a 18" rim.
