Heat not working on both front seat base
Old Jan 24, 2026 | 10:49 PM
ashishNJ's Avatar
Gl450
2007 . The base of the front seats won’t heat .. only the backs. Is there a separate fuse or relay for the base ?
Old Feb 5, 2026 | 03:32 PM
ashishNJ's Avatar
Gl450
Any suggestions where to look?
Old Feb 6, 2026 | 02:45 AM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
Backs work so you at least know there is power. So I'd assume its just a broken wire, so simple as something not plugged in. Maybe somebody pushed something under the seat and just unplugged the connection??
I had an old Audi that the sensor for the weight of the passenger was broken so the seat wouldn't turn on (just a broken wire, simple fix). If everything looks fine under the seat, you are going to have to pull it apart to investigate further.
Old Feb 6, 2026 | 11:35 AM
ashishNJ's Avatar
Gl450
Both seats losing heat at base seems unlikely to be wire disconnect unless they are fed by same connector. I will check and find out. Thanks
Old Feb 6, 2026 | 02:02 PM
Sallad's Avatar
Veteran: Army
08 GL320 CDI
Oh, both? Ya, thats not just a wire issue.
