Radar Detectors that Integrate.
Old Apr 8, 2013 | 10:44 AM
GeorgeJ's Avatar
2005 SL65 w/RENNtech Stage 2, 2013 MB GL550
Smile Radar Detectors that Integrate.
Was wondering if anyone had installed a radar detector in the new GL that would integrate and use the voice command system? Just got my 2013 GL550 and need some more toys for it.
Old Apr 8, 2013 | 12:33 PM
JoeMa's Avatar
26 EQS 400 SUV, 23 EQS 580 SUV (sold), 19 X7 (sold), 17/14 GLS550 (sold), 13 GL550 (sold)
I don't have any comments on your question but I would like to see some pictures of your 550. (I have a 550 on order due in May)
Old Apr 8, 2013 | 04:43 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Don't know of any that will do that.... however, I do have the Escort 9500iX Passport detector that is probably the most "intelligent" of the detectors available. The only downside is, as with most, the power cord and the suction cup window mount, however, i found that with my new GL450....it is fairly unobtrusive.
Old Apr 9, 2013 | 09:15 PM
tbradley70's Avatar
aviator
Check out mid city engineering.
Old Apr 15, 2013 | 10:01 PM
Shellbmb's Avatar
14 GL550; 14 E63s
Before you invest too much time or money, I'd make sure it works properly before hard-wiring it or integrating it too much. I have a 2009 GL550 and apparently the glass is/was a bit different on the 550. My Valentine will not sense any bogeys from the front. Only the side and rear. I've double checked it with my other valentine unit in my other car and even sent it back and the unit is fine. The glass is either "IR" glass or "blue" glass. whatever it is, it doesn't work. Some have suggested a "sweet spot" somewhere on the glass, but I haven't found it.
Just FYI.
Old Apr 16, 2013 | 08:02 AM
blittle's Avatar
Just FYI.
MB shows two sweet spots on the 2013 front glass..... one at the top around the rearview mirror and the other at the lower center of the glass. My Escort works fine on the lower spot and my EZpass module works on the upper spot.
