GL550 exhaust tip style?
http://www.ebay.com/itm/Mercedes-Ben...QAAOSw9mFWJ18l
I use an old Matress Duvet to lay down, hard part was remove the lower balance since I didn't remove the bumper, I just follow the screw positions from the new lower balance, they are exactly in the same position from the old one, on each side is a small "nut" don't forget that. Remove tips and brackets first, I believe take me about 3-4 hours but I am not an expert. The lower balance is silver color, is not chrome since originally was designed for the GL63
166-490-15-27 (exhaust pipe) [same as ML63/GL63]
166-490-16-27 (exhaust pipe) [same as ML63/GL63]
166-885-69-25 (Lower cover; Skid Plate) [GL63 only]
166-885-17-14 (pipe shield) [GL63 only]
166-885-18-14 (pipe shield) [GL63 only]
I have a question.
If your would change the muffler of the 550 with one of a 63. I had a look under both of them and they look the same.
Would you be able to get the sound of the 63 out of there, or does it have a different down pipe as well?
Thnx in advance.
http://www.supersprint.com/ww-en/mer...bo-v8-12-.aspx
https://mbworld.org/forums/market/802615
