Radar Hardwire GL 350
Old May 16, 2015 | 01:36 PM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
The 2015 has different wiring. I wasn't able to find a hot. I tried maybe 30 different combo and nothing worked.
Old Jul 16, 2015 | 11:11 AM
sblvro's Avatar
2020 C8, 2020 defender 110X, 2019 720S, 2014 GLK 350 4matic, 2015 escalade platinum, 2013 RRS HSELux
Originally Posted by shak
I tried that, my 9500ix displayed low voltage and turned off. Maybe MB uses less than 12v for the glove box lights? This was on 12 w212
MB has low voltage in all the wires. It is the voltage spike that's important to use for tapping.
Old Aug 30, 2015 | 04:20 PM
pittx52011's Avatar
GL 550, BMW 550
Question
Ho folks
Hello and thank you for your post. I recently purchased a GL 550, and wanted to hard wire radar detector, have done that before in my BMW 5 series in the overhead console. However I really find it hard to detach the console in GL class than the BMW and was concerned that I may end up breaking it. I have a pry tool set (
Amazon.com: Amico Auto Vehicle Blue Loudspeaker Audio Dismantle Removal Pry Tool Set 4 in 1: Automotive Amazon.com: Amico Auto Vehicle Blue Loudspeaker Audio Dismantle Removal Pry Tool Set 4 in 1: Automotive
true&ref_=oh_aui_detailpage_o02_s00) even that didn't work. Was wondering how much force to remove the console or any particular instructions as to how to apply the force. I will really appreciate that.Thanks a lot.
Old Aug 30, 2015 | 04:25 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
What year GL ?..If it's ike my '13 ML you insert a flat tool like a spatula under the back edge between headliner center and push it in to "release" as tab which will then allow this end of the console to pivot swing down
Old Aug 30, 2015 | 04:27 PM
Nanook's Avatar
this
https://mbworld.org/forums/new-m-cla...tall-here.html
Old Aug 30, 2015 | 05:22 PM
pittx52011's Avatar
GL 550, BMW 550
2015, so I have to push it in rather than pull it down?
Old Aug 30, 2015 | 05:24 PM
  #32
Nanook's Avatar
Push the tool in between console and headliner until it releases..DO NOT PRY
Old Aug 30, 2015 | 05:36 PM
  #33
pittx52011's Avatar
GL 550, BMW 550
Worked, thanks
Old Aug 30, 2015 | 05:37 PM
  #34
Nanook's Avatar
there ya go...glad to assist
Old Aug 30, 2015 | 05:38 PM
  #35
pittx52011's Avatar
GL 550, BMW 550
Old Aug 30, 2015 | 05:40 PM
  #36
Nanook's Avatar
Look at my post...you'll see the wires to use
Old Aug 30, 2015 | 05:45 PM
  #37
Nanook's Avatar
Heavy red with black tracer = power...large brown = gnd
Old Aug 30, 2015 | 07:17 PM
  #38
pittx52011's Avatar
GL 550, BMW 550
Done, thanks Nanook
Old Aug 30, 2015 | 07:20 PM
  #39
Nanook's Avatar
lookin good
Old Jan 5, 2016 | 11:52 AM
  #40
TechEast's Avatar
GL550
Sorry to resurrect and old thread but I would like to do this on a '15 GL550 and follow what pittx52011 did but have a few addt'l ?'s:
1. What brand cord (inviscord / mirrortap) and what length 12", 20", etc for GL console?
2. Any issues with detector turning on / off with car ignition?
3. Any issues with detector interfering with car's built in systems, lane assist, sonar, etc?
4. Can you still fold down sun visor with detector mounted on front windshield?
Thanks.....
Old Jan 31, 2016 | 11:58 PM
  #41
Neurobit's Avatar
2021 GLE 53 AMG Coupe
Thanks.....
Ditto, would like to know this also please.
Old Mar 1, 2016 | 03:17 PM
  #42
Nanook's Avatar
1. get the longest invisicord..tie wrap the excess...better too long than too short
2. depends on where you tap..I'd look for full time power..just leave the detector on..manually turn off for days of sitting...they take very little power..9500ix has auto shut down
3.no but you don't say what make of detector but regardless you should see no issues
4.yes..mount to windshield immediatley high right side or rvm
I revised my 9500ix for a Bel STiR+
If you have not yet purchased I recommend looking into the new Radenso Pro SE http://radenso.com/ They are new and have some growing pains but it performs well and looks promising.
Old Mar 1, 2016 | 03:30 PM
  #43
TechEast's Avatar
GL550
If you have not yet purchased I recommend looking at the new Radenso Pro SE http://radenso.com/
Nanook-
Thanks so much for your reply...I really appreciate it! I see on the last post (first page) someone used a 20inch mirror tap for a GL so I will most likely get that (as the next size up is a 36 inch which may be overkill).
2. I was going to tap where you told pittx52011 to tap. Heavy red with black tracer for Power and Large Brown for ground. I think that is located on the right side of the console. I have the same vehicle as pittx52011 so I assume I should have no issues using those wires as he did (2015 GL550)
3. Bel RX65 (M4 version). Yes it's an oldie but still a goodie Still gets the job done even without the gps functionality. I may upgrade at some point in the future but not sure what to get other than either a V1 or the 9500.
4. Any specific reason why I should mount to passenger side versus driver side? I plan on using a visor mount instead of a suction cup on the windshield. Also, not a fan of the rvm mounts either....they look so obvious. I like to "hide" it as much as possible.
Old Mar 1, 2016 | 03:45 PM
  #44
Nanook's Avatar
Mount either side of mirror..when I had mine I preferred it on passenger side..if you don't run the V1 with all the additional gear/phone app etc it will drive you crazy falsing...I have one in my ZR1 and be prepared for constant falsing in the city,,,,highway it's great but with more vehicles running rear radar...lane sensing etc like Audis it goes crazy..and the 9500 as good as it was in it's day...(I run 3 right now)...there are better
Old Mar 1, 2016 | 04:24 PM
  #45
Neurobit's Avatar
Nanook,
Thanks for the update.
Not sure how old your V1 is. Mine is about six months old and I rarely get false alarms (unless I'm behind a newer Audi or a Cadillac that is).
Cheers,
Neurobit
Old Mar 16, 2016 | 07:50 PM
  #46
TechEast's Avatar
GL550
Nanook-
Just wanted to post back and advise that I was successful with the radar detector hard wire. Thanks for all your help and guidance.
Only issue I ran into is when tapping into the wires on the wiring harness, the power (red with black stripe) went into the metal fitting ok. But the ground (big brown wire) was so big it was hard to get a secure fitting of the tap into it. So I did the best I could and then I put a piece of electrical tape around the wire bundles in hopes that it eventually doesn't work its way out.
Also, did I read that there is a film or something on the front windshield that will impede signal strength of the detector which is why they suggest to mount it up high? I mounted mine on the sun visor which I like because it's out of the way.
Old Mar 16, 2016 | 07:53 PM
  #47
Nanook's Avatar
good job...drive safely !
Old Mar 16, 2016 | 08:25 PM
  #48
Neurobit's Avatar
Nanook-
Glad to hear!
Regarding the windshield, you'll be fine.
Only ones I have heard about were the prior gen S class. All the newer ones as well as the x166 do not have any special films on them.
I've just done mine also (went with the SAVVY on the V1). Easiest install ever.
Neurobit
Old Mar 19, 2016 | 11:12 PM
  #49
mustbebenz's Avatar
on GLC300 #2, a 2022 CPO purchased b/c I really dislike the X254's UI (GL350 before those)
FWIW, flipping through my 2014 manual earlier today by chance I notice an image of the windshield with zones where the solar reflective properties were omitted for uses like this and toll reader things. RTFM, as is often rudely stated (I mean it tongue in cheek) and YMMV.
Old Mar 19, 2016 | 11:33 PM
  #50
sblvro's Avatar
I know we like our V1 and the hardwired ones make it look neat. Anyway, I just found out while driving to Canada in my ESCALADE when the LEO pulled me over and ask for my license, insurance and "radar detector." I have used V1 since 2002 and have the updated one when he claims to have detected my V1. I did not see any bogeys and was surprised I got pulled over for not speeding. I guess it's time to move to a redline or passport beltronics which are spectre 3 cloaked. Sad day indeed since he took my V1 and gave me ticket for owning a RD.
