A/C odor after driving for 1+ hrs
The smell is kind of a weird faintish chemical smell, not a musty wet dog smell. I find that I have difficulty breathing when this happens and I have to turn off the AC right away. The smell clears after about a minute or less.
If I turn on the AC again usually the smell comes back reasonably quickly. However it can take some time for it to happen the first time. If it isn't hot out then it might not produce the smell at all, with say 1.5 hrs of driving. With the AC off the problem never happens.
I have had the car inspected carefully for leaks in the AC system by the dealer, even with dye in the system, but no leaks are obvious. They did replace the cabin air filter and disinfect the system as if it was a mold/mildew problem, but that has had no impact on the problem.
My first assumption was that perhaps the Freon was leaking intermittently. I guess most Freon leaks are not intermittent. Anyway, there is no obvious loss of coolant in the AC system, and no obvious leaks in the plumbing that can be seen easily. They haven't taken the dash apart to check in there because they can't repro the problem - because it takes warm weather and quite a bit of driving. Living in the NW the weather here does not require AC that often.
Has anyone else had an issue like this where the smell comes on after an hour or two of driving and smells chemically?
thanks
Jim
Now - interestingly - when I question a customer if they are leaving the temp at min - they invariably say "no" - and when they bring their rig into service, yes it is set on min..
I am not saying this is your specific problem - I am just relating that this is what I have encountered in other select instances
However you do mention that sometimes there is an acrid smell right as the evaporator freezes up, and that could be related to my problem since mine is definitely an "in use" smell. I have had it occur in the Palm Springs area, where I wouldn't expect there to be a lot of humidity to freeze up the condenser, by I don't really know.
Do you have any more info on that slightly acrid smell when the evaporator freezes up?
Jim
That's the situation that has come up on 2/3 occasions on front air.
I just bled a few tiny puffs of Freon from the AC on my GL550 to test smell the Freon and it doesn't smell much. The smell I get inside the vehicle seems stronger and sharper although both leave me feeling a bit weird and slightly dizzy. Can't really tell if they are the same or not.
Is there something going on with the freezing action where the ice expands as it freezes maybe putting pressure on the coils and causing a temporary leak in the evaporator, or maybe there is some pressure relief valve going off or something?
Any thoughts on what causes the smell?
Something is definitely causing an odor but no one knows what it is. Best guess so far is the acrid smell that fabbrisd1 mentioned when the evaporator freezes up, but my dealer certainly hasn't heard of that. I don't think Mercedes customer support has heard of that either. I don't understand why there would be such an odor when the evaporator freeze up either, but it at least fits with circumstances required to have the problem. I have never smelled this sort of thing on any other car - I would like to get it fixed. Luckily I don't us the AC much, but when I do I'd rather not have this smell.
Under "Cause" in the procedure it says "Oxidization products of the cavity preservation can enter the interior compartment via the air conditioning". The procedure involves taping over various bodyshell holes and cleaning the evaporator of the A/C unit. It says use only 2 litres of warm tap water, and don't use ContaSept disinfectant!
Maybe this info is useful to someone else...
Just to update my experience a bit further, I had thought the problem was fixed but it wasn't completely fixed. Driving in 100 deg F heat for 8 hrs, and the problem came back very strongly - I had to turn off the ventilation completely. The dealer had another go at fixing it, and apparently they learned from Mercedes that the undercoating material on the 2013 GL550 did not set properly. That undercoating combined with heat and water from the AC unit creates the noxious odor. The only way to fix it is to block all of the holes in the ventilation system and maybe the body in general that can allow air from undercoated areas of the body to reach into the cabin area.
Their latest fix to the problem involved essentially what they had done the previous time, which was to close off some holes between the body/ventilation system and the cabin. Maybe they got updated info from Mercedes about additional areas that needed to be closed off in addition to what they closed off the previous time - not sure. But this was the first time that Mercedes actually acknowledged their was a problem and they knew how to fix it. Your mileage may vary on this though since when I talked to an actual Mercedes rep, he said he wasn't aware of any issues that could cause the problem....
Jim
Where is the undercoating located?
I get headaches, dizziness, sore throat from the chemical odor when engine is hot.
Most dealerships are unaware of these issues and just say nothing is wrong. How do I address problem with dealerships?
thanks!
In my case, I have a 2013 GL 450 and had experienced the AC bad odor for several thousand miles. I don't know if the above fix was ever applied to my GL and I don't seem to get the smell anymore. One of the service agents recommended that the AC settings should be always set to auto... you do not manually change the temperature setting. Even if you change to a lower or higher temperature ...always click on auto. I keep the temperature to around 70 - 72 degree and use auto. It seems to have done the trick...but keeping my fingers crossed!
Thanks for the advice.
Most smells coming from vents are from bacteria, mold, mildew and actually non-toxic. They might stink momentarily but they don't get you sick. That is a myth that industry propogates.
VOC offgassing and engine fumes are the real toxic chemicals.
The cabin filter does nothing but prevent dust and dirt from entering cabin. These organic materials don't get people sick.
thanks
Jim
