Power Tailgate issue
Old Mar 15, 2016 | 07:30 PM
sberry's Avatar
2017 E300 (W213), 2016 GL550 (X166) (SOLD), 2012 CL63 AMG (W216)
We have a 2016 GL550. Our garage is a little shorter than the max tailgate height and the tailgate will not save the tailgate height limiter. I have pressed and held the close button and it does nothing. Is this an issue for anyone else?
Old Mar 15, 2016 | 11:37 PM
sg021's Avatar
2014 GL450
Are you saying nothing happens when you press and hold the button on the tailgate, or does it eventually beep to indicate it theoretically stored the position?
I haven't had any issues with mine.
Old Mar 16, 2016 | 08:18 AM
sberry's Avatar
It does nothing when I press and hold the button.
Old Mar 16, 2016 | 10:17 AM
GL-'s Avatar
GL-
2016 GL450
Is the press and hold at the time you're stopping the lift gate before full open, or after it has stopped (like you would press it to close the gate)?
Old Mar 16, 2016 | 04:40 PM
sberry's Avatar
I have tried everything, pressing and holding while it opens, waiting for it to open then move it and press an hold. It doesn't work.
Old Mar 16, 2016 | 04:52 PM
Mike450's Avatar
2015 gl450
I believe you have to press stop at desired height, release button, and then depress button again and hold.
Should be an audible tone to alert position saved.
Old Mar 16, 2016 | 06:11 PM
sberry's Avatar
I've tried that. I have no idea.
Old Mar 16, 2016 | 06:29 PM
sg021's Avatar
2014 GL450
It's not functioning correctly. There's no trick to how it works, all you do is move the tailgate to the height you want, then hold the button until it beeps. Sounds like you'll need to get it looked at.
Old Mar 17, 2016 | 08:48 PM
mtm's Avatar
mtm
gl450
Did you try to save a position at different heights? I think I remember mine not saving if the position was close to fully open.
Old Mar 17, 2016 | 10:51 PM
fabbrisd1's Avatar
A gaggle of MB's
My suspicion - before she had opportunity to set opening tailgate height correctly -at some bought the rear hatch was grabbed/put-down, or grabbed/way-up - which in turn kicked a safety - I "think" the rear hatch will need to be-erased aand then coding willl take in.
