Need help with Passenger side Exterior Mirror
Someone hit my passenger side mirror and it cracked. I have ordered a mirror and am awaiting its arrival.
I need all your help. I have done multiple searches, and am unable to find a method specific to X166.
I spent 2 hours trying to get the mirror out yesterday, but am not progressing as I am scared of breaking something. Methods tried are:
1) Removing the housing first. This is clearly not working, as the mirror is in the way
2) Trying to pry the mirror out. This seems to be the logical approach. The method I want to try is to point the mirror down, and then carefully put my fingers behind the mirror to loosen it from the motor mount.
Any suggestions from you guys? Please help. Does anyone have WIS? Please look up this method and advise.
I have looked for days.
. I bought WIS from a guy on EBAY and its not working despite multiple attempts. So I am back to good ole fashioned car repair, with common sense and caution
*removed
Last edited by sg021; Aug 1, 2016 at 05:10 PM. Reason: removed not applicable videos
These videos wont work, as the X166 has a torx bolt that prevents the housing from coming off. The access to the torx is only AFTER the mirror is removed.
Plus in the X166, the mirror is in the way of the housing, unlike these videos where the housing can be removed with the mirror intact.
Trust me, i tried the technique in the first video, and it does not work. the mirror obstructs the path in X166. Not to mention the torx bolt.
Is there any other tool I can use to make this easier?
Special Thanks to you, not to mention all forum members who helped out with this. Replaced the mirror yesterday. Such a painless job, esp. after Jim's guidance.
Everything is working well.
