NEWBE GL550 questions
Got a used GL550 about 6 months ago.
Did some research here prior to buying, seed like minimal complaints problem
Read about some Brake ROTOR is etc... factory fixed most?
My question is-
When the car has been driven for awhile. 30min or longer, when I park I think I can smell the slightest burning sensation coming from under the Hood.
No smoke, and does not smell like Brakes.
Hood and side are slightly warm after a little while if they were not already.
Gauges are reading normal temps, no warnings in the DASH
Oil looks good (also got it changed 500 miles ago.
I smelled it BEFORE the oil change.
No leaks that I can detect.
car has 84,000 miles
Help?
Larry
My question is-
Help?
Larry
Well at least you "smell" a burning sensation rather than "feel" a slight burning sensation.
Does it smell like oil burning? You may have to pull the under-panels to inspect.
lashburn (04-10-2017)
I probably should have chosen better words than "Sensation" LOL
I would say more of an oil smell than brakes...
What might I be looking for, ?
Is this a known area of concern??
thanks for quick reply
Well I've only owned my GL for a couple of months but have had a 163 (ML430) and 164 (ML350 bluetec) prior to my GL350 and from my experience with the ML430 the burning oil smell came from the valve cover gasket. In my 164 I vaguely smelled oil when the oil cooler leaked but more so on the turbo seals ($10 and $30).
So I'd pull the under panels to see/feel if they have oil on them (which may indicate a leak (or spilled oil) and while the panels are off take your time to sniff and look around with the flashlight. I'm assuming you've already checked from above.
Yep, black panels. There are probably 6 plastic bolts or less. Comes right off.
I'm not sure about the difficulty level on the x166s. I'm sure most of the time is spent removing a top layer of hoses and harnesses trying to get to the actual cover and it's bolts. I'm sure the gurus will chime in soon enough.
!st - did we catch the Model Yr of your GL550 ?\
Please check coolant level - and advise if you need to "top off" to fill mark..
If a 2013/2014 then yes - there can be a minor coolant leak detected only after full-warm-up..
At 84K miles either you have a high mileage X166 or a low mileage X164 - which is it ?
Are you under Mercedes CPO warranty - or did you buy off-the-street ?
I am not under any warranty, bought from used Dealer non MB
I will check Coolant, thanks for the Tip
If a 2013/2014 X166 - then yes - it is NOT uncommon for whatver "pipe" is in there to develop a minor leak - MB later changed supplier for that part later-half MY 2014
Coolant leak
Can you provide some details on the Coolant leak? Where was the leak from?
I can smell the coolant burning as well, but don't see anything on the face of it.
