Speedometer with segments "red lights"
Old Jun 2, 2017 | 11:41 AM
billybenz's Avatar
2006 CLS 55 AMG
Took 2014 GL550 for oil change and when I got it back the red lights on speedo that show you where the speed you selected do not light up ? They used too , The cruise operates fine/distronic is this a setting the repair shop shut off any help is appreciated. Thank you
Old Jun 7, 2017 | 03:44 PM
Mob17's Avatar
GL350
Hi new member here. From the UK and recently purchased a GL350.
I have the same issue as above. The speedometer segmen lights light up on ignition but after that i never see them on whilst using cruise control. Getting the garage i bought it from to have a look but it would be useful to know if there is an option or something that turns it off?
Old Jun 12, 2017 | 06:16 PM
Mob17's Avatar
GL350
Anyone please?
Old Jun 20, 2017 | 02:32 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
where did you take it for an oil change? Dealer or second hand mercedes service?
Old Jun 22, 2017 | 06:32 PM
SaniDel's Avatar
2015 GL 550
Tried the Distronic "cruise control" on a long and fast stretch of highway. The two red lights on either side of the speedometer needle definitely illuminate when cruise control is engaged AND you are cruising at the set speed. Once you get within range of another vehicle and your speed drops they no longer illuminate ... I think, but what would be the purpose if the needle is no longer between them?
Old Jun 30, 2017 | 05:55 PM
Mob17's Avatar
GL350
The garage said apparantly my car doesnt have the segment lights. I think thats bull because on ignition they all light up! Any ideas? I might have to take it to Mercedes if no answers...
Old Jul 1, 2017 | 10:29 PM
Jpkcpa's Avatar
2013 GL350
Paid closer attention to mine today. When I set cruise a segment lights at the set speed as long as I maintain that speed. When the car senses a vehicle ahead travelling slower, it appears that the segments between my set speed (high limit) and the speed of the slower vehicle (low limit) all illuminate. As the car adjusts to the environment (decelarate and accelerate) the segments adjust accordingly. I could be way off, but that is my initial observation.
Old Sep 10, 2018 | 06:14 PM
mhab12's Avatar
2008 S63
Just took in my 2014 ML350 Bluetec for service and got it back with the same issue. Still no solutions? Will have to take it back to the dealership.
Old Sep 21, 2018 | 11:54 AM
Bluesky555's Avatar
2014 gl350
did you find any solution on this issue? What did your dealer say? I got same problem with the res lights on my 2014 GL350. Thanks...
Old Sep 21, 2018 | 11:59 AM
mhab12's Avatar
2008 S63
The dealer had to reprogram the speedometer. Exact text from the invoice says, "Connected battery charger and ran short test and no codes related to issue. Went into instrument cluster and reset control unit for speedometer and now working properly."
Old Sep 21, 2018 | 06:31 PM
Bluesky555's Avatar
2014 gl350
do you mean if service at second hand mercedes could do something wrong with red light? I always service at outside shop...
Old Apr 25, 2019 | 05:30 PM
el-condor's Avatar
w246
I have found the solution for this problem, which is free of charge and will take you max. 10 minutes to fix it. My car was also at the service recently, where they did the reset of the service interval and after i got my car back, this function did not work any more.
I assume there is a software bug that cause this function to be disabled whenever they do a service interval reset.
Solution: just disconnect the car battery from the car and leave it disconnected for 5-10minutes. I am talking about the battery which is under the hood, not the one inside the car - auxiliary battery.
This solution worked 2x for me already.
Old May 2, 2019 | 05:48 PM
DC-BENZ's Avatar
GL350 Bluetec and GLS580
We don't have batteries under the hood.. Are you sure about that?
Old May 3, 2019 | 11:42 AM
el-condor's Avatar
w246
Yes I am sure... i have a B class model, but the problem was the same as yours. Mine car has battery under the hood.
Old Mar 1, 2021 | 06:44 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
I’ve noticed the red segments on mine do not work anymore either when using D+. Any other fixes besides a battery cycle?
Old Mar 10, 2021 | 07:25 PM
Ricardoa1's Avatar
2014 GL550
Same on mine, no segments on distronic
