Big bill to pay or buy prepaid maintainance.
Unless the dealer was nice enough to say the brakes and rotors wore out prematurely and get MB to pay for it. Very doubtful considering you didn't even buy it from them.
Typically through the CPO process, brakes and rotors as well as tires must be within a certain limit/specs. Else the dealer will have to replace them during the CPO process.
I read you can still buy extended prepaid maintenance on BMW that will also cover wear items. No idea of pricing, but you can bet it will be very costly.
Mercedes pre-paid maintenance (3-pack) for either A-B-A or B-A-B does not cover wear items. In my case, when I bought the CPO, the A service was already done. So, my 3 pack will be the B-A-B (which is more costly than A-B-A if paid individually) and it cost me $1500. I think list price is prob $1800??
For next 3 services included for $1500, you can be damn sure it will not include wear items such as brakes and rotors. And BMW will prob charge at least $3k if it includes wear items.
1. Prepaid Service -As MB prepaid maintenance is non-refundable - (1) decide how many miles/yrs you plan to keep your GL (2) price the 40K-50K-60K service with your dealer if purcahsed as needed (3) compare that as needed cost to cost of prepaid maintenance - 40K service is a "bigger" service - I do think prepaid will save you some dough
2. Tires and Brakes are wear items - which can by done by any competent shop - does not have to be done at dealer.
Great tires - like Michelin - are going to be $1,000+ for set of four - again - wherever you get best deal. Use Tire Rack as benchmark for tire selection and target tire cost
Brakes - do a forum search OE equivalent rotors and pads for a GL450 are not a arm and a leg as they used to be 3-4 yrs ago - OE quality parts are available independently - source the parts - then any compentent tire/brake shop can install.
Keep the beat !
Since it is a 3 pack, it automatically becomes the next 3 service which may be BAB or ABA.
Just call the service center up and inquire about buying the 3 pack prepaid maintenance. You can buy from any MB service centers. They will prob quote you different prices. Get the one with the lowest as you can use it at any MB dealership.
In any case, the GL has a brake wear sensor which will light up in case it reaches the wear limit. Absent this signal, I won't take what the tech says at face value.
Unscrupulous service centers will typically try to "scare" uninformed owners into these things. Brakes and of course rotors much be replaced as well.
Still two things I don't understand. On all my previous cars, the front brake pads wear out WELL before the rear due to the physics of braking. I never had a problem replacing only the axle that was worn out. But maybe the MB system is so sophisticated that it REQUIRES both front and back be replaced at the same time?
And the rotors. I can't believe that a set of rotors have to be replaced at 35-50,000 miles. Granted they may have some wear and you don't want them pulsating when you brake. So MB's rotors cannot be machined at all? Again, I know the brakes are sophisticated, but I didn't sign up for that kind maintenance with such lows miles.
In my case it won't be a huge deal as I only drive 5,000-7,000 miles a year. But geesh!!
In any case, who knows if the service tech was just eye-balling or actually measured it. It may or may not need replacement yet. Just go with the signal telling you it is at the wear limit. Perhaps the previous owner driving habits was causing it to wear out eventually at 40k, but OP driving habits may be able to extend it out to 50k.
However, in this thread, the OP says he's only at 27k miles and need brakes and rotors.
https://mbworld.org/forums/gl-class-...out-there.html
Personally, I bought the CPO at 17k. I'm at 30k now. Still no signal telling me I'm at the wear limit.
