RedLine 0W-40 Oil
I am not sure if anyone is using after market Oils in their Benz such as AmsOil\LiquiMoly\RedLine. My warranty expired last month, the car is still under ELW though until 2021.
I am debatting hard this time to put REDLINE 0W-40 in my car, I already put REDLINE 5W-40 in my 2017 Audi A8 L 4.0. And that oil does make difference, I could see a slight performace improvement and tapit\engine sound has lowered drastically. these are good to have things, but the major reason for Redline is the viscosity index and being Group V oil which is true true Synthetic it will protect the engine from wear.
What you guys think about Redline please let me know, and I been a loyal customer for Mobil 1 and I am still but that Group III base stock it uses is just not convincing me any more to purchase Mobil 1.
If you seek to use a boutique oil, why not something like LM? They're fully compliant. If you don't care about that, you can essentially use any oil.
https://www.redlineoil.com/0w40-motor-oil
- Suitable for VW/Audi 500.00/502.00/ 503.01/505.00, BMW LL-01, water-cooled Porsche A40 and Mercedes-Benz 229.3/229.5 applications
- Used in Dodge Viper and many later Chryslers (MS-10725)
- Better flow at extremely cold temperatures compared to 5W40 and 10W40
- Recommended for API SN/SM/SL/CF and ACEA A3/B3/B4
Here's a study on 5W-30 synthetic. Not exactly what you're looking for, but it will be close I think. I know this study is conducted by Amsoil, but when you are running a defined ASTM test it doesn't really matter who does it.
http://wpc.1c96.edgecastcdn.net/001C...ml5/index.html
Red Line makes good products, I have some in my basement. I guess if you're out of warranty, less of an issue.
Anyway I know there are die hard fans of Amsoil and I also use them in my other Japanese car but for German I feel only comfortable with Mobil. Redline I just started using so not sure how it would come along will advise you on that as my Audi A8 already has it.
For Benz I am debating should I go with RedLine 0W-40 or not.
https://bevo.mercedes-benz.com/bevol..._en.html#close
Liqulymolly is the best. Far from aftermarket.
Oem certification and everything.
I used the liqui molly 5w40 in the w163 and 14 audi q5 and vw gli. All three run amazing.
In the x164 I bought castrol edge 0w40 European formula on sale (only reason why) and it is so much better than the 8 previous dealership oil changes that use mobil 1. Really the mobil 1 sucked. It always made the engine whine at cold temps and you could tell the car was suffering from inadequate oil formula. I felt so sad for the car hence I stopped using the dealership for oil even though still under aftermarket warranty
Anyway That oil is good as well because the additives they put is at par. As you mentioned Cold Cranking on Mobil 1 is tooo loud. And it hurts me when I heard the loud noise knowing that my engine is getting Fcked.
I believe trying 1 oil change going for 6-7000 miles on Redline shouldnt hurt, what you guys think?????
I think you got it wrong. High tech is what they sell in Europeand is full synthetic
Synthoil is the lower gradw one for us formulation.
I trust Liqui molly. Their design and attention to detail is amazing. Ive used the ceratec and engine flush kits as well as fuel injector cleaners and they really do work as they say unlike my experience with royal purple.
Technical data
Viscosity index
HTHS at 150°C
Pour point
Evaporation loss (Noack) Flash point
Total base number Sulfate ash
Color number (ASTM)
Areas of application
180
DIN ISO 2909
>= 3,5 mPas ASTM D5481
-45 °C
DIN ISO 3016
10,0 % CEC-L-40-A-93
232 °C
DIN ISO 2592
11,3 mg KOH/g DIN ISO 3771
1,0 - 1,6 g/100g DIN 51575
L 3,5
DIN ISO 2049
i may have contaminated my new oil long story . But can that engine flush you mention above be used to flush my OM642 diesel oil and possibly free up some current flow problems?
Base oil group plays a big role in oil engineering plus the additives. Some oils use group 3 with high class additives which is as good as Group 5 base oil. But here the main thing is how natural you like, and group 5 is the most natural you get.
Like Ultra Thin "Life Style" vs Bare Skin
If you know this difference then you would know what Redline vs Mobil vs Motul is LOL.
