Turn signal stalk acting up
Old Aug 1, 2023 | 11:42 AM
  #51
Weeve's Avatar
ML 350 W166
Just found this thread. Perhaps exact same issue as mine. I added a thread earlier (Turn signal increasingly intermittent W166) as I have the random no turn signal issue. Did the swop for a new module solve the issue long term? Thanks.
Old Aug 1, 2023 | 12:00 PM
  #52
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Speaking for myself, so far the issue hasn't returned.
Old Aug 7, 2023 | 01:47 PM
  #53
bwiele's Avatar
2017 MB GLS 450
Hi - if you are still very generously helping strangers who have this same problem, would you please look up the part number for VIN 4JGDF6EE7HA755672?
Many thanks in advance if you are able to help,
Brian
Old Aug 7, 2023 | 02:29 PM
  #54
mekantor's Avatar
Brian
Sure no problem, I believe yours is A 166 900 92 07 9051.
Although A 166 900 01 08 9051 also showed up in EPC. It is not listed as a replacement for another part, but has a note "from 12.06.15"
Maybe its a GLS thing, that there are 2 different parts listed? Dealership might be more hopeful to sort out the distinction. For my GL it still looks the same, 1 original part and 1 newer direct replacement.
Old Aug 7, 2023 | 03:33 PM
  #55
bwiele's Avatar
2017 MB GLS 450
Thank you so much for your help. I will try to figure out which one is the right one.
Best regards,
Brian
Old Aug 19, 2023 | 05:45 PM
  #56
bwiele's Avatar
2017 MB GLS 450
Just circling back to close the loop on my experience - I reached out to the dealership in FL that was recommended (benzpartshq.com) to order the part that mekantor told me was the one for my car. As he suggested, there's an updated part number for this part and they were able to help me sort that out. The list price for the multi switch is $535, with their online purchase discount the price of the part was $400, they also recommended replacing the steering wheel bolt and buying the clip which self destructs when removed. Total cost for those additional parts was $8.50.
I'm a DIY type person but definitely not an automotive mechanic. I followed the process described here and watched a few YouTube videos and then just started the project. All in it took me 1:15 start to finish (which was a lot less than I expected). All the switches & functions worked perfectly after the swap. I had my first drive of over an hour last night and I'm very excited to say my problem with the blind spot turning off and the blinkers not working did not reoccur! I'll need to take few more trips to be 100% confident the issue is resolved, but I'm feeling good about it so far!
mekantor - I'm going to send you an e-mail this weekend so I can figure out how to compensate you somehow for the help. We were literally at the end of our rope with this problem (which had gotten to the point that it happened every time after driving an hour). The dealership was of no help because the won't drive the car an hour to duplicate the problem, so we were getting to the point where we were potentially going to have to replace the car. Now we don't have to!
Very happy outcome. Thanks to all.
Old Aug 24, 2023 | 04:47 PM
  #57
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
Mekantor, can you help identify the part number for my VIN - 4JGDF2EEXDA176615.
I have experienced the same behaviour and been living with it for a few months so finally ready to tackle this before the winter comes through.
Thank you in advance.
Old Aug 24, 2023 | 11:03 PM
  #58
mekantor's Avatar
The newest iteration of your part is A 166 900 02 08 9051, good luck!
Old Aug 25, 2023 | 03:56 PM
  #59
Mikey178's Avatar
Thank you Mekantor. Appreciate the quick response.
Old Aug 28, 2023 | 03:13 AM
  #60
Highside23's Avatar
ML350
Hi Mekantor. Any chance you could explain the differences depending on VIN? I have already bought a second hand part but not yet fitted it. I didn't know there were different part numbers!
Thanks in advance and for your help to everyone on here, it's taken me ages to find a decent answer to my problems.
Old Sep 7, 2023 | 02:37 PM
  #61
Bigapple's Avatar
2015 E350
Yes replaced that entire thing, should match the part number based on your VIN or an updated replacement part. Be careful because there are lots of trim and other options for it. I have an EPC subscription so if you're unsure then DM your VIN to me.
Hi Mekantor, If you're still helping could you please assist with my part number for vin WDDHF8JB3FB085211. Been having this issue for few months now.
Old Oct 20, 2023 | 07:46 AM
  #62
AK_FIN's Avatar
MB CLS 350 CDI (X218)
Hi Mekantor! Can you help identify the part number for my VIN - WDD2189931A081035
Thenk you in advance. WDWDD2189931A081035D2189931A081035
Old Oct 23, 2023 | 04:41 PM
  #63
mekantor's Avatar
The part number showing up for your car is A212 900 78 15 9051. Good luck!
Old Jan 6, 2024 | 12:03 PM
  #64
Kebm's Avatar
2014 ML350
The entire assembly on the X166 chassis comes a single component. If you'd like to DM me your VIN, I can look up parts details in EPC for you.
mekantor, hi! Could you look up the correct multifunction switch for my ML350 please?
4JGDA5HB2EA345903
Old Jan 7, 2024 | 09:42 PM
  #65
mekantor's Avatar
4JGDA5HB2EA345903
Hello, the current part number for your VIN is A 166 900 04 08 9051, good luck!
Old Feb 9, 2024 | 01:51 PM
  #66
Gill Senderov's Avatar
Mercedes GL450
Hi Mekantor, Will you pleas help identify the part number for my VIN- 4JGDF7CE7DA104240.
I thank you very much in advance.
Old Feb 12, 2024 | 10:19 AM
  #67
mekantor's Avatar
Hello, the current part showing for your VIN is A 166 900 99 07 9051
Old Feb 12, 2024 | 09:30 PM
  #68
AleksVT's Avatar
GLS63 AMG, W213 Wagon
Hi Mekantor,
Could you please help me out as well?
My vin is 4JGDF7FE3HA754488
Also, does anybody know the part number for the module connecting clip?
Thank you in advance!!!
Old Feb 15, 2024 | 11:03 AM
  #69
mekantor's Avatar
Originally Posted by AleksVT
Hi Mekantor,
I believe yours is A1669009507 9051.
One of these is probably the clip, they are cheap so perhaps get both: A0008230245, A0015459373
Old Feb 15, 2024 | 11:33 AM
  #70
AleksVT's Avatar
Hi Mekantor,
Thank you so much for your help!
Do you know the difference between these two part numbers:
166-900-99-07-64-9051
166-900-04-08-9051
Thank you again!
Old Feb 15, 2024 | 11:44 AM
  #71
mekantor's Avatar
Hi Mekantor,
166-900-04-08-9051
Thank you again!
A16690004089051 has code +835 on it for "South Korea version" so I figured that wouldn't be the right one.
Also your car's datacard has code 806 - "YoM X5/1" ... A16690004089051 does not include that one, but A16690095079051 does.
For both 9051 is the color code - Black
P.S. - I don't know where you found 166-900-99-07-64-9051, I don't see it for your VIN.
Old Feb 15, 2024 | 12:51 PM
  #72
AleksVT's Avatar
Thank you so much for your help but it's so confusing....
I asked buymercedespartsnow.com the same question and this was their response:
166-900-99-07-64-9051 does not apply to your vehicle. 166-900-04-08-9051 shows to be the correct one for that VIN.
Old Feb 15, 2024 | 01:10 PM
  #73
mekantor's Avatar
EPC shows that A-166-900-04-08-9051 does apply, so it should be good. I can't find A-166-900-95-07-9051 (my original suggestion) at the typical US dealer catalogs, so maybe that one is intended for other markets.
Not sure where you originally got A-166-900-99-07-64-9051 from, but yes I'd agree it does not apply.
Old Feb 19, 2024 | 06:23 PM
  #74
Yeffsy's Avatar
2015 GL350 Bluetec
Mekantor:
I read through the X166 forum regularly and I remembered this thread because of how cool it is that you help out looking up the right part number for people. Yesterday we took a trip to the mountain and our 2015 GL350 started doing exactly what is described here. Can you look up the correct part for my VIN 4JGDF2EE7FA546163? I saw someone mention that the replacement bolt and clip only cost them $8.50. Can I get those part numbers also?
Thanks...Jeff
Old Feb 21, 2024 | 10:16 AM
  #75
mekantor's Avatar
Originally Posted by Yeffsy
Mekantor:
Thanks...Jeff
Hello, this is what is listed for your car: A166 900 01 08 9051
The clip is one of these: A0015459373, A0008230245. Not sure which, but they are a few dollars so if you get them please post photos. Good luck!
