M278 cam sensor leaking oil into engine harness - anyone install isolation wires?
#126
How do these extensions prevent oil from continuing to travel down the wire?
My recently purchased ML63 had oil from the cam sensors which was found all the way at the ECU. After cleaning both ends and replacing the sensors, I checked both ends again weeks later and did not find any new oil. I also replaced all cam sensors on my GL550 around 60K miles with oil traces found in the cam sensor plugs.
Has your friend given you any indication how these stop the oil and how to know when they need changing if they are used on the car?
I did change my cam mags and position sensors last spring with new ones from the dealership and didn't see any oil in the plugs of the old ones. Do you have any clue if they could eventually start leaking? I have the 2013 S550 so it's getting some age on it.
They actually do fit. I have a set on my M278. I'll let them know. These guys don't specialize in Mercedes but they engineer a lot of top notch performance parts and have the ability to make harnesses in house. So I mentioned the issue to them and told them they might be able to offer a solution.
#127
They act as an isolator of sorts. To understand how they work, you need to first understand the problem. Oil seeps through the sensor and into the plug. Through capillary action, that oil is "sucked" further up the harness where it eventually finds its way to the PCM or even other sensors. These extension wires effectively place a road block in between the sensors and the vehicle's main harness. These harnesses may eventually become fouled with oil but then your worst case scenario is simply replacing these inexpensive harnesses instead of the entire engine harness and potentially your PCM.
I believe the running knowledge is that the newer (green seal) sensors don't have this issue. For me personally, it's cheap insurance to run the extension wires.
Replacing the sensors is another solution. It's more time consuming and a little more money/ hassle. I think the issue is that a lot of people just get generic sensors, not knowing if they have the new or the old type and the old design will leak.
chassis (12-10-2022)
#128
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,936 Likes
2017 GLE350 4MATIC
^second post I have seen on this site where new magnets and sensors made a large improvement in engine performance.
I put forth the notion that replacing magnets and sensors on these engines at 100k+ mileage is good practice for preemptive maintenance.
#129
Honestly after the performance enhancement the new ones made to my engine, I plan on another $350 replacement of all cam magnets and cam sensors at 30,000 miles. $350 is nothing compared to how well the engine responds with new ones. They may very well last longer but its a nominal expense and easy replacement.
#130
2017 GLE350 4MATIC
#131
Yes, same thought process I use when I replaced ignition coils at 100k miles. It all makes a difference: spark plugs, ignition coils, cam sensors, cam magnets. DI combustion in modern engines is balanced on the edge of a knife and everything needs to be perfect to get the most power, smoothness and efficiency from the engine.
chassis (12-22-2022)
#133
#134
2017 GLE350 4MATIC
Miss means no combustion, or weak combustion, on a power stroke. Reasons for this are weak/no spark or weak/no injection.
In order of likelihood and ease of verification - reasons for weak/no spark or injection could be:
- oil in harness from leaking cam magnets or cam sensors
- bad spark plug
- bad O2 sensor(s)
- bad air temp or coolant temp sensors
- bad compression from scored cylinder
- bad injector
Read stored codes if you have no CEL. An in-depth XENTRY session will tell you alot about all sensors and actuators (e.g. fuel injector). Scored cylinders can be detected via compression and leakdown test and via borescope/endoscope.
- bad spark plug
- bad O2 sensor(s)
- bad injector
#135
They don't. Any feeling is going to be in your head. I don't want to get into a back and forth with anyone over it but I'd suggest reading about how the system works. It either doesn't (in which case you have at least one code and a noticeable reduction in power) or it does.
chassis (12-24-2022)
#136
2017 GLE350 4MATIC
Say again?
#137
It's a binary system. Position is commanded and if that position is not as expected, a code is thrown. There is no power to be picked up here. When a hall sensor wears out, it stops working and throws a code because it's unable to read the cam position and if any of them are unable to read the cam position the system defaults to off. If you don't have a code, your sensor is working. Replacing a working sensor with a working sensor as routine maintenance would offer no improvement in performance. People often don't understand how these systems function and erroneously trick themselves into thinking that they gain a lot of power after performing these changes but it's really just in your head.
The point is, if you're not throwing any codes for these sensors, your system is working and replacing anything isn't going to restore any power. It would be the equivalent to replacing your valve cover and saying you felt a power increase.
#138
2017 GLE350 4MATIC
#139
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
2014 Mercedes-Benz E350
Okay, one cam sensor I can get to is dry. The magnet solenoids are dry, but one cam sensor under intake is wet. I pulled first plug on PCM, looked ok at first. Looked closer small amount of oil residue on 6 of the pins. I cleaned up with contact cleaner and quickly hit with compressed air, hit plug with contact cleaner and air, thick layer of dielectric grease on PCM/ECU plug, till I can order sensors.
Has anyone opened PCM to check for oil and/or cleaned. I would probably just use isopropyl alcohol to clean that. I use it to clean flux after soldering on board mounted components.
chassis (01-16-2023)
#140
2017 GLE350 4MATIC
I vaguely remember a poster on this site opening up an ECU with oil in it, but search isn't bringing it up. Wet ECU is widely discussed on UK MB sites and benzworld.
steh-fan (11-03-2023)
#141
But I've got to drive 300 miles tomorrow to see oncologist, so I'll fix when I return wed.
#142
I found quite a bit, one said don't, but the rest said car ran normal after. Cleaning couldn't hurt as long as it's resealed as before. I'm ordering cam sensors, May order Magnets as they are leaking from seal to cam cover.
#143
If you have to remove your turbo pipes or anything else that has a hose clamp, be sure to get new clamps because the old ones will likely strip on you when you try to tighten them. Also use a small mirror and check bottom of your cam covers the magnets are attached to, the MB sealant on these covers will vanish and the covers will leak slowly.
#144
Sound like standard rip off by dealership. How would leaking oil affect engine harness, which is designed to sustain harsh environment. Ask them for detailed diagnostics report - could be something else.
I had same **** excuse - oooo you have oil in wires - well gfy, reason for check engine was something completely different.
steh-fan (11-06-2023)
#146
Received 3,384 Likes
MY'14 W212 M276 3.5NA @55kMi
amazing game
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/2780503300_9e93836185aed008f3b3a64bd9b843c18576b7df.jpg)
new style: shoulder outside
Original style was shoulder all the way inside on the other end.
The original extraction thread is too far from where its held tightly in press fit.
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/1040x2000/screenshot_20231106_150253_gallery_331979a486767e4f33be379bddb2f08f1918fa28.jpg)
no go!
The issue is the tensioner is short lived, like 40 to 50KMi. The shaft seals leak out pressure and help drain when stopped.
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/1642x1080/screenshot_20231106_150109_gallery_e85037b88f3dac37c31a60816b8c857de6b56e02.jpg)
machined vent drilling
One side tensioner even has a tiny vent hole machined on its side to help bleed oil/air. This way when pressure returns the air can get flushed from the highest point inside the conduit without loosing too much pressure.
My workaround to cancel VVT gear and limp tensioner issues caused by low oil pressure is to disable oil pump control solenoid.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Last edited by CaliBenzDriver; 11-06-2023 at 06:15 PM. Reason: illustrative pictures
#147
2014 ML63
Great thread , very helpful, as I'm encountered with this issue on a m157 engine , would have to check my Co@ sensors as I'm burning more fuel then normal, no CEL on or codes on my icarsoft scanner
