M278 cam sensor leaking oil into engine harness - anyone install isolation wires?
But I am wondering for the future, in order to avoid this again is it possible to install the "isolation wires"/"pigtails" between the cam sensors and engine harness to prevent this from happening again in the future? I found there is a service campaign 2012070002 for some of the engine models just prior to the M278 that apparently share cam sensor designs with the M278, and the part of the solution under that campaign was to install these isolation wires. Just curious if anyone has done that to their M278?
I had same **** excuse - oooo you have oil in wires - well gfy, reason for check engine was something completely different.
The piggy harness they came up with that's part of the fix is a sacrificial part so when the cam seals leak , it goes onto this piggy harness and gets directed elsewhere...a safestop kinda thing.
Reminds me...I still have to replace the seals on my cam covers lol.
Easiest solution would be spraying oil residue off with electric contact cleaner.
Now moneywise - on 278 it requires to take engine out to replace engine harness - one piece goes around engine. That is lots of income for dealership.
Sound lame, but one "professional" told me that cylinder head gaskets had to be baked on newer engines. To make things sound complicated.
Leaking at right side cam gear cover
-reseal cam cover, replace cam solenoid seals. No more leaks after.
Turbo line seal on oil pan leaking
-replace seal for turbo inlet. No more leaks after.
Crush ring on drain plug for oil pan leaking
-drain oil, replace crush washer on drain plug for oil pan. No more leaks after.
parts list:
1 PKCAMCOVER 276/278 ENG CAM COVE WARRANTY
1 MB001-986-71-71-09 CLEANING AGENT WARRANTY
1 MB010-989-90-71 CLEANING AGENT WARRANTY
1 MB016-997-50-45 SEAL RING WARRANTY
1 MB000000-006365 HEXALOBULAR BO WARRANTY
1 MB000-990-95-06 SCREW W RND. H WARRANTY
1 MB003-989-98-20-10 SEALANT MB WARRANTY
#2 10MBZ DRIVEABILITY INTERNAL
CUSTOMER STATES COOLANT LIGHT ON ALL TIME
PRESSURE TESTED SYSTEM, NO LEAKS FOUND, CORRECTED
FLUIDLEVEL. TECH 1880
Qty Part Number Description Unit Total
1 MB278-181-05-80 METAL SEAL INTERNAL
1 MB007603-012102 RING,GENERAL,M INTERNAL
Oil being drawn through a wiring harness by capillary action, into a connector, and isolating the connector from making contact with its mate, is believable to me.
Is there a "pigtail" solution for the M278 like the M273? Or do I need to start replacing these parts as a maintenance item, and if so, which parts?
Thank you in advance.
The root causes appear to be the cam position sensors and the cam magnets/solenoids. These are exposed to oil. They fail over time, and oil wicks into the harness and reaches the ECU and in some cases the O2 sensors. Misfires can occur.
Replacing the cam position sensors and cam magnets is the first step. If your ECU has been contaminated, it means there is oil in the harness. There is no practical way to remove oil from the harness, so a new harness is required if the ECU has seen oil. It's conceivable that ECU connector pins can be cleaned, and re-used with a new harness, sensors and magnets. But it's a guess.
If a vehicle is found to have oil at the ECU, the most conservative and expensive option is to replace:
- cam position sensors
- cam magnets
- engine harness
- ECU if exposed to oil
- O2 sensors if exposed to oil
This gives a clean starting point. If a vehicle is found to have leaking cam position sensors or magnets, but no misfires or CEL, the magnets could be replaced, and the harness connectors cleaned and observed as regular maintenance. This includes removing the ECU harness connector periodically to inspect for oil, and clean it if present.
Can anyone with the pigtail jumpers please post a clearly focused, well lit photo of the harness connectors? This will help identify whether or not the pigtails can be used on M278.
Latest part numbers:
M272
Cam position sensor A 272 905 00 43
Cam magnet A 272 051 01 77
M278
Cam position sensor A 276 905 08 00
Cam magnet A 276 156 04 90
M276
Cam position sensor A 276 905 10 00
Cam magnet A 276 156 07 90
The sensor body and magnet body is/are plastic. My view is that these black plastic injection molded housings crack in a location exposed to oil. It's an internal-to-sensor failure. The crack and leak may or may not be visible upon outside inspection, if the failure is recent or not severe. In a severe case, oil may be oozing out the connector.
Mercedes has a terrible reputation in my opinion for plastics that are barely suitable for use underhood. Barely suitable means paper thin and easily damaged, or the plastic resin degrades over time. This allegedly helps the planet by being biodegradable but owners are left with failed parts at low-medium mileage. Examples are intake ducts, vacuum fittings, radiator mountings, sensor bodies, the list goes on. Cost is also a motivator for MB, whereby use of thin gage plastic reduces plastic content and therefore cost to the manufacturer.
Summary: cracking of the plastic injection molded sensor/magnet body allows oil into the sensor/magnet interior, and the oil migrates to the sensor pins and into the harness. The pigtails are a field fix, not part of the problem.
https://www.mboemparts.com/oem-parts...ess-2711500156
https://www.pelicanparts.com/More_In...-150-01-56-M22
I'm looking at the photos, and it looks the same, but that's just based on looks...
https://www.amazon.com/Genuine-Merce.../dp/B07NS6WWYD
If it works, you’re happy.
The cam position sensors and magnets are commodity parts bin items that MB used across engines. The pigtails are simple two wire affairs. So low risk.
What may create a challenge for other engines is the local parts packaging situation and available space. For example on the M276 the intake manifold is nearly in contact with some of the position sensors, and fitting the pigtails in would be either tricky or not possible. This will be an engine-by-engine situation.
The one challenge I am not quite happy with is that to install the pigtails in each position may require the intake manifold to be removed on the M276. Not sure if it’s worth the effort. Still mulling it over. If all pigtail positions can be installed on my engine without removing other components, it helps make the decision.
