Manually enable camera while parking
Old Nov 8, 2019 | 06:18 PM
C_Bus_GL550's Avatar
GL550
Is there a way to turn on the 360 camera while parking? We currently put vehicle in reverse then drive but there must be a one-button solution, what am I missing?
Thanks!
Old Nov 8, 2019 | 08:20 PM
chassis's Avatar
2017 GLE350 4MATIC
With a W166 and COMAND, go to Vehicle and there is a sub-menu for 360 camera. Page 48 of the COMAND manual.
Old Nov 8, 2019 | 10:23 PM
rosswell's Avatar
S320 GL350
star button
Yes you can assign the camera function to the "star" button on your centre console. It was that by default when I bought my GL. Comes in very handy very often. One touch.
Old Nov 9, 2019 | 04:01 AM
GL550
Perfect, will do this. Thank you!!
Old Nov 9, 2019 | 06:20 AM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
When I pull into a parking spot, I press the star while in Drive and I get the front camera. I press the Comand button and that gives me the 360 view which tells me how well (or poorly) I am positioned between the lines.
Old Nov 9, 2019 | 07:45 PM
350gunner's Avatar
GL350
Press the "SYS" button for 3 seconds.
Old Nov 10, 2019 | 07:27 PM
GL550
Tried it today and pressing the star button changes the display to show the clock. How do you set this function to display the 360 camera? Thanks!
Old Nov 30, 2019 | 10:16 AM
C.decker0822's Avatar
GL550
Interested as well. First post. Woohoo!
Old Nov 30, 2019 | 10:31 AM
chassis's Avatar
2017 GLE350 4MATIC
Press and hold the "vehicle" button on the center stack button pad. The camera turns on in a W166. The "vehicle" button is near the red and green telephone buttons.
Old Nov 30, 2019 | 03:56 PM
GL550
Will look for that button. The “star” button turns the display to a Clock.
Old Dec 1, 2019 | 09:33 AM
robalo220's Avatar
2014 Black SLK 55 AMG, Black 2015 GL 550, 2011 Blue GLK 350
This!!! Press and hold System for 3 seconds. Front view pops up. Click down on the round control knob and 360 camera pops up
Old Dec 3, 2019 | 11:02 AM
att234's Avatar
BMW 535d
The star button is programmable. You have to program it to show the camera, as apparently it is currently set to show the clock.
Old Dec 5, 2019 | 12:08 PM
bha's Avatar
bha
13 GL350, 14 SL550
Both star buttons are actually programmable. There is a hollow star on the right and a solid star on the left of your COMAND wheel.
Go into the settings in Comand (I think it's under VEHICLE) and you can select "favourites" or "preferences" or something like that.
Then you'll see a list and you can assign one item to each star button. My solid star is programmed to be 360' camera, and the hollow star is Fuel Consumption.
Then just press the solid star and you'll get the camera at any time you are at low speed (at higher speeds you'll get a message saying not available)
Old Dec 7, 2019 | 05:32 PM
GL550
Boom, this worked great! We have a 2015 so only one Star to program as a favorite but conceptually it works the same.
Thank you.
