Best place to buy replacement air intake hoses
Old Jan 26, 2020 | 02:52 PM
Shellbmb's Avatar
14 GL550; 14 E63s
My redneck duct tape solution is no longer working. I've seen some on eBay for like $70. Anyone else have a good source for replacements?
Old Jan 26, 2020 | 03:08 PM
Joseph~'s Avatar
2008 R320 CDI 4MATIC
FWIW....
Look up on FCP euro, may cost more but you have lifetime replacement guarantee.
Regards
Joseph~
Old Jan 26, 2020 | 04:27 PM
hambone1983's Avatar
2015 GL550
I bought two of these and hooked them to the ends. Been almost a year and they are holding up extremely well. Cheap and looks nice.
https://www.amazon.com/gp/aw/d/B000BPZ55Y/ref=ppx_yo_mob_b_inactive_ship_o0_img?ie=UTF8&psc=1 https://www.amazon.com/gp/aw/d/B000BPZ55Y/ref=ppx_yo_mob_b_inactive_ship_o0_img?ie=UTF8&psc=1
Old Jan 26, 2020 | 04:34 PM
Shellbmb's Avatar
14 GL550; 14 E63s
https://www.amazon.com/gp/aw/d/B000B...?ie=UTF8&psc=1
Did you buy 2 per side so 4 total? Or 2 total? Both of mine are toast.
Old Jan 26, 2020 | 05:52 PM
2015 GL550
I purchased 2 from Amazon. One packet has one hose and two rubber ends. One hose per each side. I’ll take a pic of mine shortly today. It looks sweet. Even my Benz dealer thought it was slick. They acknowledged the factory piece is crap and breaks easily.
Old Jan 26, 2020 | 07:30 PM
DC-BENZ's Avatar
GL350 Bluetec and GLS580
MB Dealer online
https://www.mboemparts.com/ I ordered mine from there..
Old Jan 27, 2020 | 07:21 AM
captivabenz's Avatar
14 GL 350, 23Chevy Bolt EV and 22 EUV
Would replacement of these intake hoses be covered under MB extended warranty. ? Mine are torn and I have coverage until 10/24/2020.
Old Jan 27, 2020 | 08:44 AM
blevinson's Avatar
2014 S550, 2013 GL450
My hoses were covered under the extended warranty.
Old Jan 27, 2020 | 08:45 AM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Depends on your relationship with your dealer. I think they are wear and tear items. I got one replaced by the dealer, noting "goodwill" on the invoice. Pretty sure they did not try to claim back from MB. I've seen other posts where the dealer would not replace as a warranty item.
Old Feb 4, 2020 | 11:48 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Got two from eBay. Holding so far so good. You can give a best offer for some of the listings there and save some.
Made in China.
Old Feb 6, 2020 | 03:23 PM
KamranT's Avatar
2013 GL 450 4MATIC
Hi,
I shop from here; www.autohausaz.com
prices are good and quality as well.
Old Feb 9, 2020 | 09:18 AM
Shellbmb's Avatar
14 GL550; 14 E63s
I decided to try the Amazon solution listed above. The hose is way longer than you need so it requires some trimming, but it seems to be working fine so far.
Old Feb 10, 2020 | 05:06 PM
black06c230's Avatar
mgLipGD
I have used this setup for last 2y. Check occasionally and added a zip tie to hold better bc it would get lose
Old Feb 10, 2020 | 05:29 PM
Monksterman's Avatar
If these guys have the part, they have a lifetime warranty!! https://www.fcpeuro.com/products/mer...sch-2114705894
Old Oct 13, 2020 | 07:32 PM
Shellbmb's Avatar
14 GL550; 14 E63s
So my amazon solution was working OK, but I decided to buy a part from the AZAutohaus. The part looked like the OEM part so I installed it no problem. Today I got a check engine light. Related? Not sure yet. I guess I'll put my amazon solution back on and see if it goes off. Seems odd that the more OEM solution would thrown a CEL.
Has anyone else had this issue? Could be a completely unrelated CEL as well.
Old Nov 5, 2020 | 10:21 PM
Joeyowl's Avatar
MB GL 450 4matic 2013
Smile
yup! I followed your lead and I can't be happier. These look 100% better than the flimsy OEM.
Thanks hambone1983.
Old Nov 5, 2020 | 10:26 PM
Joeyowl's Avatar
Smile
You need one per side. I cut just a little off and its all compressed with gives it a more solid look yet.
Thanks hambone1983.
Old Dec 7, 2020 | 06:08 PM
Yeffsy's Avatar
2015 GL350 Bluetec
I've got a 2015 GL350 and I need to replace my driver's side intake hose. The hose is about 3" in diameter, but it's oval-shaped. Has anyone tried fixing these with something like the Spectre 3" hose suggested above?
Jeff
Old Nov 16, 2022 | 02:29 PM
MercWyo's Avatar
W211 E55 AMG
I just recently did the Spectre hose fix. It actually seems like it will work pretty well. If you leave the previous adhesive on and just tear off the fabric part, you can heat the adhesive up on the plastic with a torch and burn off any remaining fabric. Then just slide the adapter on while the adhesive is soft. I also sealed with gasket sealant, but it likely won't need it.
The factory attachments have an inner ring and an outer ring(outer ring visible in the pictures above). The spectre fitting slides between the inner and outer rings on the factory mounts. Might need to heat up the rubber fittings a bit from spectre to get them into a the correct shape, especially the one that is stuffed into the tube from factory.
Only one day into it, but i like the way it went together.
Old Nov 17, 2022 | 10:19 AM
Ricardoa1's Avatar
2014 GL550
I would not use plastics hoses to retrofit a fix. The pipes are fabric to allow some air in the intake when resistance is high on the tubes. Most of the air comes from the fresh air snorkel but when the there is not enough some will pass through the fabric if vacuum is present. Use a fabric replacement.
Old Nov 17, 2022 | 12:30 PM
oldmangrimes's Avatar
GL450
I've had the Amazon replacement on my 2013 GL450 for a couple years. The tubes have deteriorated slightly from the high heat (I tow regularly, sometimes up mountains in the summer with max load, so my engine gets hot), they look like they won't be a forever solution. But the Mercedes originals didn't last either. If the Amazon (well, you can buy it from Autozone, too) tubes need to be replaced, I'll probably just put the same type in there again.
Old Dec 14, 2022 | 11:11 PM
dryrunner's Avatar
GL550 Wife, LS460 & LC Mine
You won't pull a vacuum as the inlet duct is plastic and open. Unless they somehow get completely blocked. Then you have a bigger issue.
