Aux Video (Amazon Firestick) & COMAND NTG 4.7
Old Sep 19, 2022 | 01:54 PM
  #51
ctyler85's Avatar
2014 GL450
Trying to get this working. I can get everything working on the rear component inputs, but when I try the front AUX cable I get nothing. I did order the 166 kit, however the MI cable I got was an 003 number compared to your 002 number. I was messing with the different inputs and trying to mix the around to see if the pin out was wrong. What I finally did find was that if I connect the Video signal from the HDMI converter, to the video shield, I get an image, but thats the only way I can get an image, So im trying to go through the pinouts for the control unit but its hard with no numbers on the connector.
Old Sep 19, 2022 | 04:11 PM
  #52
Jason Stewart's Avatar
2013 GL550
It is possible that the cable you received is only allowing 1 “signal” through (as opposed to 3 signals: video, left audio, right audio). Can you post some photos of your cable setup?
