Aux Video (Amazon Firestick) & COMAND NTG 4.7
Finally trying to get this to work - having issues. I may have the wrong type of RGB aux cable, as I just found it in my bin of cables. I have two of the HDMI/RGB converters, so don't think that is it. I have the OEM interface aux cable as well. Will do more troubleshooting, it just has to work sooner or later!!!
Can you give me some hint how to get this done?
The cable you have is just for USB and Aux Audio input; it does not allow video input via the 1/8th cable.
But this thread may help: https://mbworld.org/forums/m-class-w...scription.htmlSurprisingly, this cable kit can't be found inexpensively on Amazon or elsewhere, but I did manage to find the kit for $50 on eBay. It took about 4 weeks to arrive and in combination with "3.5mm to 3 RCA AV" (also known as a "1/8" TRRS AUX Male(CTIA) to RCA Male Stereo Audio Video Cable") I was able to get external video to show up on my COMAND screen!
3.5mm to 3 RCA AV
In my case, my end goal was to attach an Amazon Firestick to my system, which itself would run an emulator to play vintage video games. The Firestick Lite is connected to an HDMI to RCA converter to enable it to connect to the 3.5mm to 3 RCA AV cable (which is then connected to the 1/8'' female Media Interface Cable, which is plugged into the Media Interface port in the center console armrest.
Here's an image of the cable connections:
How to connect a Firestick to NTG 4.7 via Media Interface
Here's a video of the setup working:
Amazon Firestick on 2013 Mercedes GL550 (X166) COMAND (NTG 4.7)
In my case, I paired the Firestick with 2 8bitdo sn30 pro bluetooth game controllers to enable the retro gaming piece.
information about emulation gaming on an Amazon fire stick can be found here:
Information about customizing the Amazon Firestick here:
customizing the firestick
Adding a device with an app ecosystem to the COMAND system really enables a whole host of new functionality; for example, you can mirror your device's screen (phone, tablet, laptop) to your Firestick and show the content on the COMAND screen. Even more possibilities when paired with a Video-in-motion unlock!
Thanks in advance
If you're not getting audio, it's possible that the Red, Yellow and White cables need to be rearranged. In my case, the cable that was outputting audio (which is supposed to be Red and White) was actually the yellow cable. Try switching your cables around in different combinations to see if that helps get your audio working.
As I will use the Aux cable only for video and Audio
I need the sticker at Aux, no means to buy the entire kit
I can source it separately, mine produced vifeo using yellow, remains red and white which obviously not carrying any video..
Please let me know if I miss anything else here
Finally got things working, my Hdmi to AV was faulty, however I recognized a noise sound.. Buzzing once you increase the sound beyond a certain value.. I assume this is ground loop noise.
Had you face so
My staff was working great until I mess up the command engineering mode.
I can see the video clearly and i can lesson to Audio as well, however wherever I connect so to car... No Audio... Aux enabled, fuses checked and works.. Not sure if something went wrong in hardware or a fuse at the head unit itself which allows only video although same connector the 3.5 mm shows video without audio.
Any idea is much appreciated
I recognized that video is On and grayed out... While Aux also is On ( not grayed out), Most On, External Amplifier is set... All sounds working along with video except the Sound with the video as it played video muted from the Aux Input
You have an "AV 2 HDMI" adapter ~ but you need an "HDMI 2 AV" adapter
The video pass through series should be Firestick > Adapter > AV Cable > Command
So the video input>output direction needs to follow that series flow.
Get the right adapter and it should work.
EDIT: I figured it out and fixed the "No Aux Audio via AMI Port" issue.
For a separate reason (Roadmap CarPlay Installation) I had been messing around in the Engineering Menu to see if I needed to enable "Aux" Audio option (even though, in my case, I already had the AUX menu item in the main infotainment screen) and in the process I temporarily turned off "MOST" in 7.5 the TGW Parameter menu (which is a trick to enable "Audio Aux" selection in 7.7 HU Parameter menu) which reset the Audio Source and UCI (Universal Control Interface?) parameters to the incorrect settings for my vehicle (correct settings for Harmon Kardon systems is Audio Source: External Amp; UCI: Installed). I did the following to fix get Audio working through the AMI port again:
- Enter engineering menu, enter 7.7 HW Parameter menu, change Audio Aux to Off. Press and hold COMAND on/off button to reset COMAND.
- Enter engineering menu, enter 7.5 TGW Parameter menu, change Most to Off. Press and hold COMAND on/off button to reset COMAND.
- Enter engineering menu, enter 7.5 TGW Parameter menu, change Most to On, change Audio Source to External Amp, change UCI to Installed. Press and hold COMAND on/off button to reset COMAND.
- With COMAN powered on, check to see if you can hear Audio through your video source plugged into the AMI port (via Video > Aux or Audio > Aux). Should work!
NTG 4.7, 7.5 TGW Parameter Screen
NTG 4.7, 7.7 HU Parameter Screen
Last edited by Jason Stewart; Mar 19, 2022 at 12:00 PM. Reason: Added additional context
