Auxilary Battery Malfunction
Old Feb 8, 2021 | 11:09 AM
sthuluvath's Avatar
2015 GL 450
I have 2015 GL 450 and getting an Auxiliary battery malfunction. I think this battery needs to be swapped out.
Are these normally covered under extended warranty? If not, how much do these run for for parts and labor?
Old Feb 8, 2021 | 01:26 PM
Jim Ma's Avatar
S 550, S65 Coupe
I Just replaced mine over the weekend by myself. I bought the Battery from FCP Euro for $50. All I had to do was remove the sill by the rear hatch ( 2 torx and then just pull up to free the clips). Then lift out the tray with the Spare tire tools, The gray cloth lining below that needs to be moved to get access to the battery by removing the 2 black pins on the right side and you can fold it back out of the way. The battery is right there to the right in a bracket. Just need a 10MM socket on an extension to remove the bolt and it comes right out. Then replace the battery and put everything back together. Think it took all of 5 min start to finish. Really easy if you are even slightly mechanically inclined.
Old Feb 20, 2021 | 01:56 PM
captivabenz's Avatar
14 GL 350, 23Chevy Bolt EV and 22 EUV
My 7 1/2 yr old GL 350 needed prophylactic replacement of both batteries. The auxiliary I did myself, followed Jim Ma’s advice. Battery arrived in 4 days, replacement was 15-20 min without incident.
I think I’m going to the local Indie shop for Main Battery replacement.
Old Mar 13, 2021 | 01:29 PM
steadysupreme's Avatar
2013 GL350 Bluetec
curious how do i know if my Aux battery is dead? i just changed my main battery and car still won't start. This is on my 2013 GL350.
IF Aux battery is dead, does it usually have a warning message on dash?
thanks in advance.
Old Mar 14, 2021 | 06:18 AM
Error codes, erratic behavior in electronics, and the like. I wanted to avoid these potential problems on a 7 1/2 year old battery.
Sams Club will replace my main battery with a Duracell AGM H 8 next week, ~ $ 180.00.
Old Mar 14, 2021 | 11:45 AM
chassis's Avatar
2017 GLE350 4MATIC
Prophylactic battery change, both main and aux, is good practice for all vehicles, and MB vehicles especially because of high electronic complexity.
Old Mar 16, 2021 | 03:50 PM
mikapen's Avatar
That's true, as is "check the grounds."
Old Aug 18, 2023 | 03:45 PM
nycrx7's Avatar
C250
all screws removed but couldn't get the battery/bracket off
Hi guys, also have a 2015 GL450, auxiliary battery looks to be dead...
I was able to get to the bracket post the 2 black pins, then removed the bolt to get the metal piece holding down the battery.
Then removed the 4 nuts - 2 on the left/front side of the battery, 1 in the back/bottom, and then 1 bolt to the back side ... so 3 on the floor, 1 on the back (tail light side).
I also removed the +/- out and pulled the vent plug out. That's when I ran into trouble... the "screws" are pretty long, so I was able to get the bracket out in the front (where the 2 on the floor, either front side of car or left side of battery looking at it in the trunk), but was unable to get the back 2 parts of the bracket from the screws (the bracket itself hit some metal piece, so I couldn't pull it up far enough to get it off the bottom bolt or the bolt coming from the tail light side. What did I do wrong? Please help... can't believe I'm contemplating taking my car in somewhere to get a battery changed...
and one more thing, from Jim's post, it sounds like he got the battery out after just removing the bracket holding it down... and the +/- ..? no clue how thats possible with the space limitations...
Old Jan 20, 2024 | 09:03 PM
Zernen's Avatar
2016 gl 450
Same issue as nycrx7
Having the same issue with my 2016 GL 450. Have the large auxiliary battery located in rear wheel well. Seems to not have enough room to remove the harness or battery. Some guidance would be wonderful.
