X166 Timing Case Coolant Leak
Evidently, the entire engine has to come out to access and replace the timing case. I'm not inclined to pay that kind of money on a car I bought for $23k (86k miles) 4 months ago, so I'm trying to determine how likely it is (or soon it will be) that this leak will turn into something much worse.
Dealer says that there are 2 seals in the timing case... the 1st seal has failed and it leaking coolant. 2nd seal is intact. Dealer said that if the 2nd seal also fails, coolant will start to mix with oil, which will eventually destroy the entire engine (coolant mixed with oil reduced lubrication capabilities of the oil). Right now, dealer has found no evidence of coolant mixing with oil (no milky-looking oil). I have to add a little bit of coolant about once or twice every 5000 or so miles.
My current (wishful?) thinking is that the first seal was never supposed to fail, but it did and lasted 'til now (93k miles); maybe the second seal will last the next 93k miles or forever. I've never heard of this problem, and am not familiar with this part of the engine, so not sure if this is a reasonable line of thinking.
What do y'all think? Is coolant leaking in the timing case (but not yet mixing with oil) something you would A.) Definitely fix right now B.) Monitor for now, fix later C.) Not worry about it.
Ask an indy shop for a quote. I don't agree the engine needs to be removed. Engine removal is likely specified by MB / WIS. If you have the radiator replaced and the timing cover seal replaced at the same time, there is synergy in these jobs and potential for cost reduction.
GL550 X166 Timing Case Reseal Parts List from Dealer
The list is a laundry list of things "to do while you're in there". While not a bad practice to do preventive maintenance, the root cause seems fishy. I would either take it to an indy, DIY or just do the radiator replacement. The parts list also suggests they plan to remove the engine to do the front seal repair.
I read through several of the WIS procedures related to the front seal replacement, and it doesn't appear to me that MB specifies engine removal for this job.
I did end up taking it to an independent mechanic and they said that my primary concern should be the radiator at this point. The said they radiator was leaking bad enough that they couldn't tell if there were additional leaks elsewhere. So, I'm going to start with replacing the radiator, then have them pressure test the system and see if they can replicate the timing seal leak. In the meantime, I will check the oil dip stick once a week to see if there are any signs of milkiness (coolant + oil).
In the meantime, I was able to find this Technical Service Bulletin that seems related to this topic:
VIN: 4JGDF7DE3DAXXXXXX
OIL OR COOLANT LEAKING FROM TIMING CASE COVER PASSENGER CAR TECHNICAL TOPICS; JULY 2015
Reference Number(s): TT 07/15, Date of Issue: July 2015 MERCEDES-BENZ: Models "All with Engine M152/M157M278" GROUP: 01.40 - Crankcase, timing case cover, end cover
TOPIC
Oil or coolant leaking from timing case cover
CAUSE / EXPLANATION
The timing case cover has a drain hole that can leak oil or coolant when the front cover is not sealed correctly to the block.
CORRECTION
The drain hole is located near the thermostat piping. The drain hole is difficult to see and may be easily missed by technician diagnosing a coolant leak. Also the coolant may leak out of this location very slowly and not leave much evidence behind.
Resealing of the timing case cover has been successful in most cases. Only if there is a casting flaw in the sealing surface would replacement of parts be necessary.
What part of your radiator was leaking? i've been dealing with a strong coolant smell for past two years. Both times taking it in for service at dealer and no coolant leaks at all and pressure tested as well. Tech says my coolant lines are ok, and the smell of coolant is "Normal" smell. Shouldnt have a strong coolant smell after driving for 30 min and car is parked. I walk past front of vehicle and can smell coolant. Again tech says "Normal" to smell coolant. No leaks identified.
