Gl350 oil pan leak and motor mounts
Any idea on the book hours to change the motor mounts? Their rate is $117/hour. The said the pan seal is very involved including front differential removal or displacement? Much appreciated....
Now there is a rip off. If they resealing oil pan - you don't have to pay full amount of work for changing engine mounts - because they will have to disconnect those anyway and changing it will be unscrewing one bolt. Transmission mount is an easy fix.
Don't recall hitting the pan or otherwise anything that would have caused the seal to leak - only other work down under that I have had under warranty is the entire def system and exhaust system - glad it was warranty @ ~$10k including transfer case leak they discovered during the def repairs. Maybe the sealer guy on the line had a hangover when it was built? Ha. Haven't a clue but will ask if any indication of cause when it is disassembled.
Now your engine mount attached to engine with one bolt. So literally to change engine mount during oil pan sealing is to unscrew one bolt on top of it and put a new one.
Transmission mount usually connected to cross member which is usually attached with four bolt to car body. Mount itself usually two bolts to cross member and two bolts to transmission...
That is all the work to do it.
The only thing they suppose to charge you extra - is a time for changing transmission mount. Period.
I am still convinced that it is not an oil pan. But a oil cooler leak.
If the issue is not resolved - no reason for you to pay.
I have project car I got for a change 2009 e class with same diesel engine. I will assure you that my oil cooler leak looked like rear seal leak and everything else leak. I had oil literally dripping from the motor as it was running. Once I did oil cooler seal replacement - have completely dry engine.
