Keyless go module fuse
Old Sep 9, 2021 | 08:09 PM
MBQureshi's Avatar
MB GL450
Hi All. I have been searching the forum for few hours and hoping someone can point me in the right direction. I'm looking for the fuse that controls the keyless go module. I have read the list of fuses on the location chart but Keyless go is not listed so I'm thinking it is part of another system. My keyless go stopped working today on both fobs. Replaced batteries on the fob but still no luck. When trying to push button start, console says key not detected.
I'm thinking to check for a blown fuse and even if the fuse is not blown, removing and re installing it may reset the module
Old Sep 10, 2021 | 12:38 PM
chassis's Avatar
2017 GLE350 4MATIC
Key not detected faults sometime go away on their own.
Fob new batteries are a must.
Failure point is usually the door handle or fob. You need to do systematic diagnosis to narrow down what is working and what isn’t.
start button works?
each of the four door handles touch-lock work?
each of the four door handles touch-unlock work?
liftgate exterior button works?
Old Sep 10, 2021 | 04:12 PM
MBQureshi's Avatar
MB GL450
Hi Guys. I don't know if the system is fused. I was hoping some one would chime in with appropriate comments. I have put in fresh batteries in the fobs
Related to the questions below
start button works? Nope
each of the four door handles touch-lock work? Nope
each of the four door handles touch-unlock work? Nope
liftgate exterior button works? Nope
Anyways, I have an appointment scheduled at the dealer to get it looked at
Old Sep 11, 2021 | 04:11 PM
chassis's Avatar
2017 GLE350 4MATIC
Does the key start the vehicle when the start button is removed, key inserted and turned?
What year is the vehicle?
Old Sep 12, 2021 | 03:49 PM
MBQureshi's Avatar
MB GL450
2015, and yes the key starts the vehicle. I can also lock/unlock using the buttons on the fob. Just the keyless functions are not working
Old Sep 12, 2021 | 04:10 PM
chassis's Avatar
2017 GLE350 4MATIC
Couple more:
interior door lock buttons work on all 4 doors?
liftgate button works on driver's door?
liftgate close button works on liftgate (red button)?
all of the tests listed on this thread have the same results with both fobs WITH FRESH BATTERIES?
The candidates are:
- fobs
- antennae (there are approx 6 antennae)
- control module
How many miles on this vehicle?
What is your history with it / how long and how many miles have you owned/driven it?
What is the entire service history of this vehicle to the best of your knowledge? Accidents? Water damage?
Old Sep 12, 2021 | 04:54 PM
MBQureshi's Avatar
MB GL450
Answers below
interior door lock buttons work on all 4 doors?. I only have lock buttons on the front doors and yes both work
liftgate button works on driver's door? Yes
liftgate close button works on liftgate (red button)? Yes. Both red button and the lock button on the lift gate works
all of the tests listed on this thread have the same results with both fobs WITH FRESH BATTERIES?. Correct fresh batteries
The candidates are:
- fobs. If this is the case it is strange of them to both die at the same time
- control module
I'm also thinking antennae of module. More likely the module (hence my reason for starting the thread).
How many miles on this vehicle? 90,800 miles
What is your history with it / how long and how many miles have you owned/driven it? Bough the vehicle in 2017. It had 14k miles on it.
What is the entire service history of this vehicle to the best of your knowledge? Accidents? Water damage? Regularly serviced at the MB dealer. Have had few non regular items replaced. Both front struts, center console a leaking XM antenna etc. No major history of any electrical issues. No history of accident or water damage that I know of. I did check carfax before purchase it matched the known history.
Old Sep 12, 2021 | 09:16 PM
chassis's Avatar
2017 GLE350 4MATIC
Thanks for answering all of the questions. Do you have a scan tool? As Plutoe suggested you need to see what's going on electronically. This icarsoft is used by memers on this site: https://www.icarsoft.com/Product/s-2...oft_mb_ii.html
Xentry is best (dealer scan software) if you have it. benzninja on this site can provide more info on Xentry.
Just for kicks, do you have any signs of water infiltration in the rear? For example, broken/torn/folded liftgate seal or taillamp gaskets? Check in the spare tire area for signs of water. The X164 is well known for this and it's not clear if W/X166 are free of this.
Old Sep 12, 2021 | 11:06 PM
chassis's Avatar
2017 GLE350 4MATIC
From X164 but the symptoms seem similar to yours. A new module is probably close to $1000. Use your VIN in mbparts.mbusa.com or http://mbepc.net/#gsc.tab=0 to search for the module.
https://mbworld.org/forums/gl-class-...le-failed.html
Old Sep 13, 2021 | 10:09 AM
MBQureshi's Avatar
MB GL450
@chassis thank you for the tips about scan tools and the parts website. I'll look up how much the module is. The appointment is scheduled for this Friday so that will probably happen before I can get the appropriate scan tool/software. Will let you guys know what the dealer says
Old Sep 17, 2021 | 09:49 PM
MBQureshi's Avatar
MB GL450
Update: Dealer reset the keyless go module and updated the module software. All keyless go functions are working now
Old May 14, 2024 | 02:18 AM
momo00122's Avatar
2015 e350
Need help with reset
hey what do you mean by rest the keyless go module? Do you know how to do this or I have to take it to the dealer to fix this?
Old May 14, 2024 | 07:44 AM
MBQureshi's Avatar
MB GL450
it was done at the dealership. I'm not sure what is involved in resetting the module. I would reommend taking it to the dealer
Old Sep 22, 2024 | 02:48 PM
AZAB's Avatar
Found the Keyless go module fuse for the W166, but...
The fuse is located at an unaccessible spot next to main battery under front passenger seat. #56
