Need help identify this part ‘13 GL 450 V8
Old Apr 29, 2022 | 06:10 PM
randy19's Avatar
acura rsx
Leaking hose under passenger side turbo charger
Zoomed in
Old Apr 30, 2022 | 08:10 AM
chassis's Avatar
2017 GLE350 4MATIC
It’s either coolant or oil. What does the fluid smell like when you wipe some with your fiber and smell it? Is it dripping on the driveway/garage floor?
Old Apr 30, 2022 | 12:51 PM
randy19's Avatar
acura rsx
definitley oil. Reason i found out is the “check oil level next refueling” popped up that made me look around. Very scant drippage in the driveway, undercarriage cover is catching it so far.
Old Apr 30, 2022 | 01:03 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
That is the area where oil usually dripping from cam sensors or front cover....
Old Apr 30, 2022 | 01:04 PM
chassis's Avatar
2017 GLE350 4MATIC
Not uncommon. Try the search feature - turbo oil leaks on M278 and M157 are posted on this site. A V8 owner will be along soon with more input.
Old May 1, 2022 | 10:02 PM
randy19's Avatar
acura rsx
Well finally able to look under and this is what I saw. Looking at passenger side turbo bottom part. Hoping its just a simple o-ring replacement and not the whole turbo assembly itself
Old May 1, 2022 | 10:31 PM
chassis's Avatar
2017 GLE350 4MATIC
Yep, seems to be a fair sized leak. Try the search feature. Turbo oil lines seem to come up now and then for the M278 engine on this site.
Old May 1, 2022 | 11:32 PM
randy19's Avatar
acura rsx
yeah been doing that all evening. Will update once I get it fixed.
