2014 GL550 Spark plug removal and replace in 278 engine
As to doing it yourself - it is a pain because of the two spark plugs closest to the firewall. Very little room. Make you life a lot easier and get a proper wobbling socket for the plugs. I used a regular socket and a wobble extension and it was next to impossible to do the last two plugs.
Additionally, the spark plugs on m278 must be indexed, so make sure you have a good torque wrench. Also, depending on how many miles your GL has, you may consider replacing the coils while you are at it, as they are not crazy expensive. In any event, a tool for pulling the coil leads from the plugs helps as well (the kind that grabs the lead at the plug, rather than pulling on the lead)
What does " the spark plugs on m278 must be indexed" mean in the quoted message? Does it only mean they have to be torqued properly, or does it mean something more than that?
Thanks!
Indexing means making sure the open side of the spark plug tip faces a specific way, in this case somewhere within a 90 degree radius towards the center of the motor.
There is some debate about whether this is really necessary however.
Some say absolutely, some say just torque them down to factory spec (23 nm)
P.S. changing plugs yourself is not what I would categorize as a fun job... as one previous poster noted the plugs near the back of the motor, particularly on the passenger side are not easy...imo not only do you need a wobble socket, but a variety of extensions and swivels is useful depending on which plug you are doing. I found that a set of long needle nose pliers with the curved end specifically for hoses is helpful to get the coils off...depending on age and condition they might be a little stubborn, but I popped all mine off fairly easy with those pliers.
I thought this would be easier than the 157 on my W212 E63S, and it was actually more difficult as I had to disassemble the rear firewall plastic inserts and factory braces to access the rear plugs better. Plus the height of the truck makes working on the back plugs more challenging...just my $0.02
The dealer is such an incredible rip-off.
The head unit in my GL550 died and, just for *****s and giggles, I went to the dealer to find out how much a new one would be.
The unit was $4k and "installation" was $1k...I told the guy, this is why Benz's depreciate so hard, because the dealer makes it punitive to own one out of warranty. (I ended up getting my own unit repaired for $800...still not cheap, but an incredible bargain comparatively)
Regarding the indexing, even factory plugs (which are just Bosch with a MB logo on them) don't always line up the right way when torquing to factory specifications...I had to end updoing the method that YouTuber "Exotic Car DIY" used: sanding the crush washer down in order to get the plugs to index in the right position...
Are Germans really good engineers? I used to think so but now I am having a different opinion. Their cars are not that reliable and their design making their cars so difficult to repair, I really don't know if I would call that great engineering.
Thanks!
Thanks!
