Airmatic - no faults/no sag - compressor runs a lot
2017 GLS450, wife's car. Within last 12 months, I've installed new Arnott compressor, valve block and Bilstein rear bags (both sides). In the last month or so, I've noticed compressor switches on quite often, every few minutes or more, but no codes on dash. Scanned with my Foxwell bidirectional scanner and haven't gotten any faults repeating themselves, except for the y51-y54 damping valves "Not OK" on all 4 solenoid 1 valves (y1) and "Not OK" on both rear solenoid 2 valves (y2). I just changed valve block again and no change.
Some of the sporadic, non-repearting codes I've gotten in diagnosing it over the last month are:
C156B00 - time for filling compressed air reservoir exceeded.
C02A100 - Control unit 'N3014 (Electronic Stability Program control unit) has detected an overvoltage.
Any ideas what it could be? The car not sagging in any corners is really throwing me off. Even monitoring level sensors live data isn't helping, they all stay about the same except for the obvious bump compressing them momentarily.
Thanks for any advice in advance!
I agree on compressor wear, hence my concern. I've sprayed everything around the compressor and valve block with no luck. I'll check individual connections on all 4 corners and reservoir today to see if there's any indicators. The weird part, to me, is there hasn't been anything on the dash, just the scanner. Figured it has to be something else due to all 4 solenoid 1 valves showing "Not OK."
I did read yesterday in one of the W model forums that some people have had airmatic issues when their aux battery was dying and needing replacement. Anyone else ever heard of this being a contributing factor?
Yes, for me it was the pump. If I recall it was take of the PS front wheel, remove the spash guard, inside the splashguard mounted to four rubberized mounts sits the pump.
Edit: if the pump is leaking somewhere internally, perhaps system pressure isn't sufficient for an "OK" status on valve solenoids 🤔
