Tailgate only happens half way
Old Jan 11, 2025 | 09:11 AM
remix919's Avatar
2006 CLS500, 2005 S430, 1998 SLK230
The tailgate on my 2013 Mercedes GL550 only opens halfway, I've tried opening it up all the way and holder the tailgate close button but I don't hear any beeps. I also hooked up my scanner and monitored the tailgate position, at half open the sensor thinks it's fully open. Does anyone know where the limit sensor is on these vehicles?
Old Jan 11, 2025 | 09:51 AM
trigital's Avatar
W213 All-terrain
You can check into cluster menus as may be limited by a garage function.
Old Jan 11, 2025 | 09:57 AM
remix919's Avatar
Do you know how to check it on the facelifted models? I saw a video of how to do it on the older models but it seems the newer models you use the tailgate button to set it.
Old Jan 11, 2025 | 10:05 AM
trigital's Avatar
W213 All-terrain
Did you check the cluster menus?
https://mbworld.org/forums/m-class-w...ate-issue.html
https://mbworld.org/forums/m-class-w...djustable.html
Old Jan 11, 2025 | 10:22 AM
remix919's Avatar
I checked those links but I don't think it's an issue with the strut, it doesn't leak at all and I tried the limiter set with the tailgate button but it didn't beep at all.
Old Jan 12, 2025 | 03:10 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I'd think a good scan tool can reset the limits that your door opens/closes to the proper points.
Just did this on wife's Jeep GC yesterday and it took about a minute. A few weeks ago I replaced the gas strut on one side and apparently it is slightly shorter/longer than the OEM one because the gate would power closed as soon as it opened all the way. Relearning the limits solved it. I might be wrong but I think the "limits" are set by how much current the motor takes during opening/closing. A locked motor will use a lot of current and that position will be remembered. Did your gate get blocked halfway when it was recently opened? It may have started thinking that was the OPEN position.
TLDR: Use a proper scan tool to fix it.
Old Jan 19, 2025 | 08:19 AM
remix919's Avatar
I did some more testing, the problem is the sensor for the tailgate is not reading correctly, at full close it's supposed to read 0.5v and at full open 4.5v. The problem is it's reading 2.9v at full close and hits 4.5v at half open. If I push the tailgate manually up to the full open positive it's then reading 0.5v which is supposed to be full close. Anyone know where the sensor is located?
Old Jan 19, 2025 | 07:27 PM
2013 ML350 Bluetec
Is there not a "special function" sub menu that allows you to calibrate full open and full closed?
Old Jan 19, 2025 | 08:02 PM
remix919's Avatar
I tried that, didn't work, the problem is the sensor thinks the tailgate is half open when it's closed and fully open when it's only half open, it must be the sensor that's messed up.
