Oil in ignition coil plug
Old Jan 20, 2026 | 05:14 AM
deeperblue's Avatar
2014 GL450
Hi,
I have a 2014 GL450.
When trying to replace spark plugs, I found that there are some oil in some of the electrical connectors of the ignition coils. The Not all of them have, only some of them.
Do you know what could be the cause?
Thanks!
Old Jan 20, 2026 | 10:21 AM
roviw1's Avatar
2015 S500, 2016 GL63 AMG
I think that is an issue with some mercedes engines, also on the S class as well. I cannot remember what causes it but it has been mentioned, I think it is best to correct it earlier rather than later. I believe you can buy small extension wires to be used, try a search on the s class forum maybe, I will also see if I can find where it has been mentioned.
Old Jan 20, 2026 | 10:23 AM
roviw1's Avatar
Preventative measures - oil separators | valve cover seeal - MBWorld.org Forums
Engine Harness Wicking - MBWorld.org Forums
