Engine Harness Wicking
MB has superseded newer longer sensors with slot openings from Continental that guarantee oil to wick straight through.
It's a reliability downgrade made sensitive to:
High engine heat
Low vehicle mileage (20kMi)
crankcase blow-by pressure
Down the line related damages are: Harness, Lambdas and ECU. Engine out repair necessary.
> 2 or 3 Pins: NO CONFUSION
MB provides 2-Pins harness extension for VVT Solenoid ("magnets") : hardly ever leak!
but does not have official pigtails for 3-Pins CPS : guaranteed leaker.
So you're left purchasing genuine knock-offs copies on eBay/Amz.
To means MB intend to keep this mature issue as-is with genuine leaky sensors and no-pigtails.
There may be ways to install lambda pigtails as used by leaky VAG cars.
-1- New CPS sensors + 3-Pins pigtails
-2- Inspect solenoids ("magnets") + 2-Pins pigtails
The key is to disable engine extreme heat soaks that are prematurely aging plastics & seals
High engine heat
This is the gospel ...
