Downpipe fitting cost / difficulty?
I’ve just purchased a cat-less set of downpipes for my GL63 and am about to contact a few shops regarding the fitting.
I wanted to know how difficultly the install is and how many hours I should expect to be charged?
I'm in two minds whether to take it to a local exhaust shop (if it’s not a difficult install) or to travel further out for an MB specialist.
Edit: my ecu already has the o2 sensors tuned out from a previous ecu tune. So no need for any programming to be done.
1 hour if they know what they’re doing, 2 hours otherwise max.
you don’t need to remove the cross member. What brand did you go with?
dont forget to buy the one gasket that should be replaced (not two, there is only one). You don’t need to but cheap insurance to get one.
What gasket is required? I don’t suppose you have a p/n?
ive done a few midpipe swaps on my driveway using jack stands. Do you think it’s achievable? Or easier to pay 2hrs labour...
worldmotorsport does the install in a time elapse in under an hour on a lift. small portion of the above video.
there is a gasket on one side, Id stop by the dealer and pick one up, I think I paid like $25 full retail. I don’t know the part number.
mine crumbled to pieces when taken off so good thing I changed to the new one!
Ended up going with one made by Brondex. Not heard of them before, but one of the main U.K. Merc tuners use the same downpipes so hopefully they aren’t too awful.
It was actually a local shop I used called AmD. I doubt it's their own tune, so its probably a mediocre tune from one of their suppliers. I was told it should be around 670hp, but as their rollers didn't extend to the wheelbase of the GL, I couldn't get dyno readouts.
It is significantly quicker off the line though - much more fun to drive. Still not a patch on my supercharged C7 vette though
Not yet sadly. Im hoping that as the GL is a pretty large and well sealed vehicle it won’t be as bad as it is on my deacatted Corvette. If it’s awful I might stick a couple of sports cats further downstream - maybe in the place of the resonators?
Word of caution to all, DO NOT purchase exhaust components manufactured by Brondex!
Their downpipes do not fit (not even close), and when you try to deal with them they are rude and arrogant. So far I have spent £150 trying to get the downpipes fitted and will be spending another £110 to return them to Russia.
Thankfully I purchased them via Paypal, or I'd be sitting on £1300 worth of scrap metal right now.
Thanks for letting us know. That probably wasn't fun trying to install then finding out they don't fit!
This company is also in Russia and has downpipes: https://www.ebay.com/itm/RSE-Mercede...19.m1438.l2649
I was thinking of buying them but hesitating now.
Where are you located? The cat-free downpipe of supersprint should fit without issue being a major producer and I believe is around EUR 1,000 from Italy. I have their mid-pipe and it fits perfectly with the OEM downpipe. I would hope the downpipe is a perfect fit too.
As you can see, the angles match perfectly, but the final straight of the exhaust is around 4 inches too long. It's almost like they forgot to deduct the length of the pipe flange from the total length. Compare that to the RSE downpipe at the bottom of the picture, and you can see that the the final straight is much shorter (like it should be). There were other issues with the Brondex too, namely the angles of the connection to the headers was totally off. But that didn't photograph well unfortunately.
As for the supersprints, I could be wrong but I'm fairly sure that you cannot install the supersprint downpipes without having the mid-pipes as well?
I've been messaging the seller in Russia about the RSE downpipes - they 100% know their stuff, was explaining all the options for adding cats (since I don't want catless due to emissions). They offer 300 cell and 400 cell that eliminate check engine lights.
You can install downpipes without mid-pipe.
https://www.supersprint.com/ww-en/sp...-hp-12-15.aspx
scroll down to:
Downpipe kit Right - Left for the Stock "Cat.-Back" system
They have different options and I believe this is the one you want. I'd call to be certain. I had to buy adapters to fit the mid pipe to the OEM cat's, so I think they already thought of that so everything can be piece meal.
€890.00 + VAT€1,085.80 VAT INCLUDEDTurbo downpipe kit Right - Left (Replaces catalytic converter)Cod: 849431
scroll down to:
It's probably different for me in the UK, but I'm hoping that I will be able to pass emissions if I run race fuel during the emissions test, or blend some fuel with ethanol for a cleaner burn. If that fails, I was contemplating running some 100cell cats down in the mid-pipe, in place of the resonators.
I
scroll down to:
scroll down to:
300/400 cell - correct, just trying to improve as much as possible. Sounds and power will be only slightly better as I believe OEM is 500/600 range. The 300 cell GEIS is an all metal flow vs. 400 cell ceramic.
The mid pipes looked solid for me and have held up with no issues, direct fit, zero modifications, no hitting anything and no leaks. I'm guessing they are thinner, but Supersprint will have the specs I hope.
Thats good to know. What sort of climate do you live in? I've had some "stainless steel" exhausts before that have gone rusty after only a few months.
The Downpipe has a reducers to connect to the OEM mid-pipe.
Nice - you didn't get the rear section? I believe you need the rear section or else you have to cut your rear muffler and weld that onto the supersprint mid-pipe, but not 100% sure. The supersprint is also a 3" diameter vs. 2.75" diameter, I forgot if it's Internal Diameter or Outer Diameter.
Cod: 849411
To be installed as a kit with 721303 or 721313 or 721323
Centre pipes kit Right - Left
Cod: 721313
Alternative to 721323 or 721303
To be installed as a kit with 849411
The center pipes make no mention of needing to be installed with any other components, so I took that to mean they bolt to ge OEM backbox.
Maybe be I should call to check on Monday 😯
I had the pipes cut and got an exhaust shop to fabricate me some 3" > 2.75" bolt-on reducers so that it would be slightly easier to put back to factory spec at a later date.
And........OMFG its LOUD!!!! Kids were falling off their bikes, car alarms were going off, elderly folks were dropping dead....all on the way home from the exhaust shop.
No smell from the decat though
Hey! Sorry for the non-response earlier.
"And........OMFG its LOUD!!!! Kids were falling off their bikes, car alarms were going off, elderly folks were dropping dead....all on the way home from the exhaust shop." That is the quote of the year!!
I love my Supersprint mid-pipe, it must sound amazing without cats.
Can I bother you to keep the car running in park and running around the car to see if you smell it? I have heard the M157 engine 5.5L V8 does an excellent job of not smelling that much due to the turbos/etc. burning up stuff and the E63/CLS63 guys are saying it's not bad but you can smell it. My only concern if it will bother my kids (odor and health wise) in case we're idling for a long time, say stuck in traffic.
So questions:
1) Do you love the sound? I love mine and would like it slightly louder (hence going catless or high-flow cats).
2) How's the odor when parked at idle from outside the car?
3) What ECU tune did you go for and your feedback.
Thanks!!!
So questions:
Thanks!!!
So questions:
Thanks!!!
So questions:
Thanks!!!
1) Imagine the stock exhaust sound amplified at least 5x but a bit more tinny, with double the whooshy turbo noise and a metric tonne more pops and bangs! It sounds nuts, possibly a bit tooo nuts. My friend in the USA (I'm from the UK) says it sounds like a big block turbo gasser. If there were a volume knob on it, I'd maybe turn it down 1 notch. In the future I can see myself maybe getting a custom rear muffler fabricated to quieten it just a little. But right now it has me laughing like a little kid whenever floor it.
2) My son took a video of me revving a few times. The car was backed up against our garage. He didn't mention smelling anything and when I got out, I couldn't smell anything either. This is very different to my diesel land cruiser I had before the GL, which stank to high heaven.
3) Local company called AmD. They don't roll their own tunes, so I assume they buy them from elsewhere. It seems like a good tune though, really shifts! I've slaughtered many M3's and M5's
1) That sounds amazing. You can hear the turbo whistle, cracks, pops and bangs!
2) I have the Brabus rear section exhaust that bolts onto the Supersprint mid-pipe (with the 3" to 2.75" adapters) and it isn't that loud when the valves are open (you can open/close) and is actually very tame when closed (very nice if you don't want to hear the exhaust).
3) You can also look at https://gthaus.com/product/mercedes-...g-v8-bi-turbo/ which is much cheaper, but is also valve controlled.
4) You can check this out for the Brabus install: http://gtfactory.ru/proekty/mercedes...rabus-exhaust/
5) I am convinced, Supersprint downpipe it is - it's the most cost effective too. I'm assuming you had no issues with the install? My supersprint was plug and play besides the adapters and nothing hits or rattles. Now I will probably wait for my warranty to expire to avoid any issues.
As far as I'm aware, the install was pretty painless. It took about 3 hours total including cutting of the OEM rear muffler for the mid-pipe.
