Weird acceleration shudder
it somewhat feels like a misfire, but I’m not getting any codes, but it seems to occur while going uphill only for a second or two…and only under light acceleration. If I do moderate or heavy acceleration there’s no problem. Strange I know. I’m going to keep monitoring it, I have one of my scanners plugged in trying to see if I get a misfire on the monitor at all. I saw some say it was their fuel injector, some said spark plugs or coil packs…or even the torque converter. I’m annoyed because i am 8 hours from home, and on the way to work for the next week or two.
What kind of oil do you use? Are you experiencing LSPI? Or, perhaps in need of a vacuum check valve?
smooth, just light load acceleration is when i get the shudder, heavy acceleration is fine. I’m somewhat feeling as though if it is within the fuel, it will be burned out sooner than later. I just usually don’t go below 1/4 tank…think i may have to and add a liquid moly fuel cleaner to be sure.
plugs and coils are new and OEM. The issue seems to have just about gone. Think it was bad fuel. When I get home though I’m doing my trans fluid and filter, diff fluids and transfer case fluids
