GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
How to verify the factory tow hitch/tow package
Old Aug 17, 2025 | 02:33 AM
SeanBaker's Avatar
We are considering buying a GL (2015 to 2018) for a family car and to tow a travel trailer. I want the max tow capacity (7500 lbs) so I want to make sure I get one with the factory tow hitch.
I've read many posts on this site regarding the evils of retrofitting a hitch, so I know I don't want to do that!
My question is: how can I verify for sure that a hitch is factory installed, and all of the "tow package" features are included? Can I do a visual inspection? Do I need to get a build sheet or window sticker?
I don't even know what a factory hitch looks like because I can't find a pic anywhere! Can someone post a pic of a factory hitch?
Thank you!
Sean.
Old Aug 17, 2025 | 01:50 PM
G63GT63SE's Avatar
2025 AMG G 63 SUV /// 2025 AMG GT 63 S E Performance 4 Door Coupé
If you can access the vehicle, activate the 360 camera system. If there’s a rear view mode for towing, called trailer view, then you can be pretty much certain it has the OEM towing package.
Old Aug 19, 2025 | 03:03 PM
resoplez's Avatar
2017 GLS 63 AMG
Check the datacard. Look for option
550 TRAILER COUPLING
Old Aug 19, 2025 | 05:01 PM
chassis's Avatar
2017 GLE350 4MATIC
Post a rear view photo of the vehicle.
Post the VIN.
Old Aug 30, 2025 | 09:13 PM
Alexie's Avatar
Look for the round, chrome hitch receiver itself. A factory hitch is integrated into the rear bumper and has a much cleaner, flusher appearance. An aftermarket hitch is bolted on underneath and will look clunkier.
The most definitive proof is the vehicle's build sheet or original window sticker. Ask the seller for it. You can also check for the physical towing prep components: a square metal hitch module under the plastic shroud behind the bumper and a trailer wiring connector (a 7-pin round socket) integrated into the bumper, not a loose wire harness.
Finally, turn the ignition on and check the central dashboard screen. A factory tow package will have a specific "Trailer" menu in the vehicle settings. If that menu is missing, the tow package is not factory.
