GLA warm up / heater issue
Is this normal? Doesn't seem so. Time for a trip to dealer to check out thermostat?
M
A 6-cylinder in a cramped engine bay (like on the GLK) is going to warm up faster.
http://de.wikipedia.org/wiki/Mercedes-Benz_M_270/M_274
The M 270 is a petrol engine with four cylinders in-line arrangement of Mercedes-Benz, which was presented in November 2011 in the second-generation B-Class (W 246). So he replaced the Series M 266 and M 274 medium as well as the model M 271 [1]
The production takes place in the Mercedes-Benz plants in Stuttgart-Untertürkheim and at MDC Power GmbH in Kölleda. The production of the independently developed by Daimler Motors began on 29 July 2011
The most striking technical feature of this engine is the ability to transverse and longitudinal installation. While the motor in the compact front-wheel drive models A and B classes transversely installed and there is designated M 270, it is disposed in the other models longitudinally and is referred to herein as M 274. This requires a very compact design of the unit. For this purpose, the auxiliary units were densely arranged and designed the cylinder spacing with 90 mm narrow. Another design goal was weight reduction. The all-aluminum engine was a hollow cast crankshaft, which reduces to the compact design, the weight in the basic version to 137 kg.
All motors of this series are charged by a turbocharger. Despite charging the engines with a ratio of 10.3 are: 1 highly compressed. First, the engine with 1.6 l displacement is (1595 cc, bore 83.0 mm, stroke 73.7 mm) built. In September 2012, followed a variant with 2.0 liter displacement and 155 kW (211 hp) in the A 250 BlueEFFICIENCY model. [3]
The M 270 and M 274 is closely related to the Blue Direct-V-engines M 276 and M 278. He accordingly has a direct injection with spray-guided combustion third generation, which is realized through an A-nozzle piezoelectric injector. In addition to the conventional homogeneous mixture formation and the layer charge is implemented in the large-displacement derivatives, which is a novelty in the engine technology in connection with the charge.
As a high-pressure pump is a single-piston pump is used with a built-in pump module flow control valve. This produces a map-controlled working pressure up to 200 bar. The fuel injection into the combustion chamber takes place depending on the load range up to five times per cycle. There ignited a multi-spark ignition, the air-fuel mixture.
The engine has two overhead chain-driven camshafts. Both camshafts [4] the timing is adjustable. This, in conjunction with the turbocharger, the so-called scavenging, in which the opening times of the intake and exhaust valve partially overlap. Here flushes the cold fresh air sucked in the combustion chamber, which is still in the hot exhaust gas in the exhaust manifold, whereby the filling cylinder substantially improved. The turbocharger to talk much faster due to the increased gas flow in the exhaust system, especially at low speeds. Thus, a turbo lag is avoided. By direct the fresh air is not mixed as it flows into the cylinder with fuel, whereby gas loss (leakage of unburned gasoline into the exhaust manifold) can be avoided.
The 1.6-liter engines are optionally available with the so-called CAMTRONIC system. This may change in partial load ranges to a smaller intake cam, which allows a higher intake manifold pressure and thus avoid throttling losses. In conjunction with the variable intake camshaft This allows a load control to the camshaft at respective loads. In the M-and M-274 270- engines a three-stage load control is thus realized in the operation with a small intake cam: At very low loads, the air flow rate is conventionally set by the throttle valve. For medium loads, the cylinder charge is set on the intake camshaft, while the throttle valve is opened at higher loads, and the intake manifold pressure is further increased through the turbocharger.
The compact design of the engine and the combustion processes require a sophisticated engine cooling. The coolant flows through a two-piece water jacket with cross flow cooling and by only three millimeters thick cooling channels between spark plugs and fuel injectors to the heat-stressed areas. To ensure an acceptable fuel consumption at higher speeds, thanks to the efficient engine cooling, a full load enrichment for cooling the cylinder head only at speeds above 200 km / h is required. In a cold start flowing thanks to a demand-driven water pump with flow-optimized ball valve no coolant through the engine. This leads to a rapid attainment of the operating temperature, thus contributing to lower fuel consumption and better wear characteristics. The vehicle interior is thus also heated as quickly as possible. Also, the thermostat includes a flow-optimized ball valve. This is electronically controlled by the engine control depending on driving style and ambient conditions and sets the optimum coolant temperature.
With a demand control the oil pump was fitted, contributing to further fuel savings. This is also the objective of the ECO start-stop function during short stops, such as traffic jams or red lights, automatically stops the engine and restarts without delay. It is the result of the simultaneous development of engines and transmissions for transverse installation. For example, the control unit of the dual clutch transmission 7G DCT communicates with the engine control unit in order to ensure the best possible response. [6] [7]
As power transmission has the following gear types:
Six-speed manual transmission with start-stop system
Seven-speed dual-clutch transmission 7G-DCT with start-stop system for front wheel drive vehicles
Seven-speed automatic transmission 7G-Tronic Plus with start-stop system for rear-wheel drive vehicles
One other piece of semi-useful/less information. Based on the numbers on the side of my turbo, it looks like its made by IHI (P/N A2700901880)
Today morning temp was -10 F outside with full tank gas it was not able to reach 60 C when i drove for 5 miles (I reached my office otherwise I would have tested it how long will it take for it to reach 90 C). Will do some more tests and see how it goes.
Your ambient temperature varied 20F between two tests, so think that is the difference.
