GLA45, GLA35 AMG (X156, H247) 2014 - present (two generations)
K-MAC 2019-2020 WHEEL ALIGNMENT CATALOG
Old Aug 6, 2019 | 09:06 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
THE FACT / REALITY IS “FULL ALIGNMENT” IS ONLY ADJUSTING FRONT AND REAR “TOE”
(IN / OUT - “DIRECTIONAL” ADJUSTMENT)
NEW CAR INDUSTRIES BEST KEPT SECRET!
(Its all to do with cost savings and ever increasing speed of auto assembly lines).
CAMBER TO ALLOW TO ADJUST TIRE CONTACT ANGLES, SPREAD LOAD MORE EVENLY.
CASTER TO ADJUST, COMPENSATE FOR CAMBER CHANGE. Also improve steering response and correctly
resolve steering pull.
BECAUSE OF BROAD ALIGNMENT PARAMETERS - dealers are able to effectively counter, fend off
the frustration of owners by advising after a FULL ALIGNMENT (above Toe only adjustment)…..
THAT VEHICLE IS WITHIN OEM SPECS - when clearly the excessive edge tire wear issues are not resolved.
LEADING THEN TO ONGOING TRIPS TO OTHER DEALERS OR ALIGNMENT SHOPS OR CONSTANTLY CHANGING TIRE BRANDS
(in the mistaken belief that this could somehow be the reason for this costly premature “edge load / wear”).
WE SAW THE NEED THEREFORE TORE-INSTATE FROM THE EARLY 90’S ONCE AGAIN “FULL
PRECISE FRONT AND REAR ADJUSTMENT”
UNIQUE PATENTED DESIGNS SIMPLY REPLACING THE 4 FRONT AND REAR (HIGHEST WEARING) SUSPENSION BUSHINGS.
Single wrench adjustable - accurately, (under load, direct on alignment rack). Instructions, extraction / insertion tubes included.
K-MAC has the experience of manufacturing front and rear adjustment kits longer than anyone else, with the worlds largest range - over
800 P/N’s. Guaranteed noiseless, long term maintenance free.
STREET / PERFORMANCE THROUGH TO TRACK DAYS - TOTAL SYSTEM. Very latest design breakthroughs including "state of the art" Mono ball / 2 axis bushings
(2 1/2 times load bearing area of steel spherical bearings), High tech “Adjustable Strut Tops” Adjustable Wishbone mounts, Subframe mounts.
ALL IN THE PURSUIT OF FRONT ROW OF THE GRID LAP TIMES - See website “About us”
Early models that have adjustment K-MAC kits are designed to double the existing range and again replacing the highest
wearing front and rear bushings.
Click here for K-MAC Mercedes Catalog.pdf
What owners say What owners say.pdf
Latest Brochures brochure.pdf
Dealer enquiries invited
