Digital Display not working
The technician could not bring the screen back up quickly so I had to leave it at the dealer. Appears to be a computer system issue.
In my car the mechanism got worse and there was grinding noise coming from the camera for a short while after the car driving the car. This led to being able to diagnose the problem and I finally fixed it. I bought a new camera housing and was able to put the original camera, and reinstall it. I took the old housing apart and a very small piece of a nylon gear fell out. It was so small it was hard to find where on the gear it fit. Now it is working after weeks of use with no noise and 100% use of the rear camera. Below is a picture of the camera housing in my car that was replace.
The thing that bothers me the most is the dealer wouldn't look at the problem unless the camera wasn't working and I left the car there to see if they could reproduce the problem. I believe the problem is common enough he should have known, or identified the cause earlier when the car was new and in warranty. It didn't cost me much for the housing, at only about $125, but I had to diagnose the problem do the repair.
Camera housing removed from the 2019 E450 but commonly used in other models
I'll appreciate any suggestions.
Thank you!
