GLB ride quality
First time MB owner. Got my 2021 GLB 250 this week after waiting for almost a month (low inventory of cars worldwide because of microchip shortages).
When I was first looking my next SUV, I test drove the X3 and Q3 as well. I eventually chose the GLB250 because of the ride quality. It was very smooth compared to BMW and Audi.
Now that I got my ordered vehicle I noticed that the ride quality isnt as smooth as the GLB demo that they had. The only difference I can think of that should make a difference is that the demo vehicle has 18" wheels vs the 19" wheels that I have. Personally, I think the 19" rims on my SUV looks way better than the 18" rims. Does a different wheel size make a difference in smoothness of the ride?
Does it also have something to do with the vehicle still being new (less than 100 km driven). The demo vehicle had more than 1500km. After I break it in will the ride get smoother?
As for tire pressure, check manually try not to rely on technology and I don't think your car has Active TPMS, I believe it only has passive so you wouldn't be able to see the tire pressure in real time.
Check the tire pressure and adjust to the tire pressure shown on the fuel door.
I set my tires to the max pressure listed on the sidewall for fuel economy and treadwear reasons. Almost no one agrees with me on this, that's OK.
Ride quality is related to how many inches of tire sidewall you have. Tire pressure has a far lower effect on ride quality than sidewall height has.
what were the tire pressures when you received the car from the dealership? Did you start at 33? or did you start at something higher then just went down to 33?
The tag on the fuel fill door states 38psi for front. It got cold last night and my tire pressure dropped to 35psi, I got warning message on my front screen when I was driving that tire pressure was low on all 4 wheels. Had to pump to 38psi for warning to go away from the car and the Me app.
TPMS reset is available to the driver and is described in the “Onboard Computer” and “Tire Change” sections of the owner’s manual.
An update on my vehicle. I decided to bring it back to the dealer to get it checked as I hear a grinding noise from my front tires when I turn the steering wheel all the way to the left when making 3-point-turns. Turns out the wheel alignment of the front L and rear R tires is bad. They corrected it of course. Now, my GLB rides smoothly, as smooth as the demo car that I test-drove.
Honestly, it's hard to believe that MB would sell a vehicle with wheel alignments that are bad.
BTW-one of my nearby MB dealers has a plate in the floor of the car wash that does some sort of rudimentary alignment check every time a car goes through. I wonder if something like that would have caught the problem.
