GLB Class (X247) Produced 2020 to Present
Glb250 2021 wheels howling
Old Apr 30, 2022 | 07:49 PM
Divadtri's Avatar
Glb250
Since couple days i start hearing strange howling on my glb250, went your turning almost on full left or right turn on the wheel’s…
is sound like howling calliper metal something what was That! Sound
my glb 2021 just bought on Last Christmas now she had 21 inch wheels 235/45r20 x9 aftermarket set.
anyone know what is that strange sound come from? I link the video on youtube
video 1 https://youtube.com/shorts/CZb5pfFYK5g?feature=share
video 2 on 29 sec howling and in 34 sec
https://youtube.com/shorts/Z_HOzbNpogs?feature=share
Old Apr 30, 2022 | 08:53 PM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
It’s hard to hear. Lots of background noises, like driving in the tunnel.
Is the sound always there or when you turn?
Old Apr 30, 2022 | 09:00 PM
Is it possible you installed tires that are too big and are rubbing on something when you turn? Tire Rack shows 245/40-21 as max size and you have 245/45-21.
Old Apr 30, 2022 | 09:09 PM
Divadtri's Avatar
Glb250
No , went i try to park went turning the wheel in slow turn 5-10 km Or like in full turn .
i dont know yet it is does went driving in the street like 50km h ,
in the first video you can hear howling just at the beginning of video . You put little volume on it to hear clearly.
Old Apr 30, 2022 | 09:31 PM
It sounds like tire rubbing against something, perhaps a wheel well.
Old Apr 30, 2022 | 09:32 PM
Did the sound start after you changed your tires?
Old Apr 30, 2022 | 09:53 PM
Divadtri's Avatar
Glb250
yes but i didn’t hear at the first time , i change tires about a month ago is started to hear this sound a couple days (3-4 )and i dont drive a lot with this car like 2-3 time week since changing summer tires.
Old Apr 30, 2022 | 10:00 PM
Divadtri's Avatar
Glb250
sorry i have 235/45r20 x9 set 4
Old Apr 30, 2022 | 10:05 PM
If you still have the original set, put it on and see if you can replicate the sound. If not than the issue is with new set.
Old Apr 30, 2022 | 10:12 PM
I am not a tire expert but you might have an issue with the wheels.
According to the link below 235/45R20 should be 20x8 not 9. Not sure what the difference is.
https://tirewheelguide.com/sizes/mercedes/glb/2021/
Old May 1, 2022 | 01:30 PM
skullbox15's Avatar
2014 C63
This is one of the reasons I only use stock rims. You've now spend God knows how much money and the car drives worse than it did from the factory.
Old May 1, 2022 | 04:35 PM
wireman218's Avatar
2022 GLC 300 4 MATIC
Look at the inside of the tire after you have done your full turn left & right while moving and see if there are any rub marks on the tire.
Old May 1, 2022 | 06:15 PM
Divadtri's Avatar
Glb250
i check look everything normal ,
and under where the wheel turn .and try in park turn full left and right couple time didn’t hear any noise is normal.maybe is the steering wheel noise why running?
