GLB Class (X247) Produced 2020 to Present
Oil Change GLB cost?
Old Oct 14, 2022 | 02:33 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
On previous cars, car manual has the maintenance requirements based on miles, but I cannot see it in the GLB pdf manual. Online shows as:
https://www.waltersmercedesbenzofriv...ice-intervals/
Synthetic motor oil replacement Every 10,000 miles
Cabin dust/combination filter replacement Every 20,000 miles
Brake fluid exchange Every 20,000 miles
Wiper blades set Every 10,000 miles
Spark plugs replacement Every 50,000 miles
Engine air filter replacement Every 50,000 miles
Transmission oil & filter replacement Every 60,000 miles (MY 2015 or newer only)
Old Oct 15, 2022 | 01:11 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Originally Posted by Vladimir Livson
Here are the links to youtube videos on how to change the air and cabin filters.
Thanks for the videos!
The cabin air filter is the easiest one I have ever seen in a Mercedes because there are no panels or the glove box to remove before getting access to the filter housing.
The engine air filter is another story. I'm not too keen on having to remove the ECU to get to it, but it's only every 50,000 miles under normal conditions.
Old Oct 15, 2022 | 10:38 PM
hammerniski's Avatar
GLB 35 AMG
lol the techs at the dealer don’t disconnect the ECM, they just ope the two tabs and unlock it and the they lay it to the side. I watched a tech change a filer in less than minutes.
Old Dec 13, 2022 | 01:07 PM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
So it was time to do service B and I scheduled it with a local NY dealer with a loaner car, plus they always wash the car (inside and out). I was anticipating to get it done under $600, but it ended up a bit more and was I just curious if it is NY pricing or standard around the US.
It ended up being $704 plus tax, less $75 coupon, I received in the mail from the dealer, a total of $685.
Old Dec 13, 2022 | 01:43 PM
tbirdvet's Avatar
GLK350
More work but I change my own oil and filters and have Belle Tire do the brake flus. Have not had the trans fluid changed yet.
I usually do my own oil changes and the filters as required. I also have my local auto repair dealer do the brake flush (usually when doing the brakes). May have to have the dealer do a trans oil change when required. Besides the labor cost at the dealer all the parts are at least double what you would pay after market. Of course much easier letting the MB dealer do everything.
Old Jan 4, 2023 | 11:30 PM
diggs718's Avatar
2022 GLB 250 4matic
Originally Posted by tbirdvet
I always have done my own oil changes on previous MB vehicles but the GLB is somewhat more difficult because it has no oil did stick for oil extraction so need to remove belly pan to get to drain underneath the vehicle but I will still try to do my own.
I feel like they figure you are going to use a pump to extract old oil nowadays anyways. Everybody I know that spent the $40 or whatever for them swear they will never pull an oil plug again and makes oil change way easier. I have a friend that said on some of his cars it actually pulls more oil out then pulling plug but not sure I believe him
Old Jan 5, 2023 | 12:24 PM
  #32
tbirdvet's Avatar
GLK350
Pump works only if you have a dip stick. The GLB does not.
Old Jan 6, 2023 | 11:44 AM
  #33
skullbox15's Avatar
2014 C63
LOL... I know. MB has flip flopped several times on dipsticks in their engines.
Old Jan 6, 2023 | 10:42 PM
  #34
Odd Piggy's Avatar
Has anyone tried to run the vacuum tube to the oil pan from the oil filter drain hole? That worked on my old E Class.
Old Jan 7, 2023 | 08:06 AM
  #35
tbirdvet's Avatar
GLK350
Have not tried this but I will guess that it is not a straight path to get to the bottom of the oil pan. I plan on making a small access panel so that I do not have to remove the entire belly pan. I also will install a Fumoto drain valve so not so messy when draining.
