GLB Class (X247) Produced 2020 to Present
'22 GLB250 SERVICE SHEET
Old Apr 18, 2023 | 11:40 AM
SRNH's Avatar
76 240D RIP, 79 240D RIP, 14 ML350BT-GONE, 22 GLB250-GONE, 24 GLC300, 26 GLC300 (on order)
Picked this up at the MB Dealership today. Depicts when Required Service Work is due based on Mileage or Length of time, enjoy.
File Type: pdf
Old Apr 18, 2023 | 12:09 PM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
Thanks for that. Very useful.
Two surprises are air filter at 50K (I expected sooner) and spark plugs at 50K (I expected close to 100K).
Old Apr 18, 2023 | 03:21 PM
SRNH's Avatar
Vlad, glad you and others can use it, as I mentioned before the Maintenance Booklet that comes with the vehicle doesn't really specify in detail when things need to occur. I'll be using it to create my spreadsheet to track my maintenance.
So far so good with the new/used '22 GLB250, certainly a different ride than the ML, really stiff so my next move when the run flats are needing replacement, to purchase normal tires and carry a "Modern spare".. Have you heard of anyone going with an oversized 255/55/R-18 vs. the factory issued 235/55-R tires, we really like the Michelin Defender LTX MS especially in the rain and snow.
Old Apr 18, 2023 | 03:30 PM
There are few threads on this forum regarding tire sizes, which you can search. Below are two of them.
https://mbworld.org/forums/glb-class...mer-tires.html
https://mbworld.org/forums/glb-class...50-2021-a.html
Old Apr 18, 2023 | 03:38 PM
I like Michelin tires as well. I installed 4 Michelin Defender LTX in October on our C-RV. They are good tires but I wanted to install Michelin CrossClimate2 instead, however they were out of stock with no option to order, so I settled for second best. CrossLimate2 supposedly are all-weather vs. all-season and should be good in snow.
Old Apr 19, 2023 | 09:13 AM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
Thanks for the maintenance sheet.
I am surprised to see that you feel that 18" wheels are stiff... You can most probably change to non RF tires to make it softer sidewalls. Going 255/55 vs 235/55 will give you 3% perimeter change which is the max permitted. I don't know what MB warranty says for not spec sizes. If you stay 255/50 vs 235/55, it is much closer to the MB spec sheet which should fit without rubbing using GLB35 spec wheel/tire sizes:
GLB250: https://www.wheel-size.com/size/mercedes/glb/2023/
GLB35: https://www.wheel-size.com/size/merc...lass-amg/2023/
You can check the calculators below for the wheel/tire changes:
https://www.willtheyfit.com/
https://www.wheel-size.com/calc/
For tires, I summarized the stopping distances in feet per mph from tirerack tests (though different temps might change the results btw different days and also different tire sizes has some impact) using the same car tests:
You can see the performance of the tires usually depends on the compound, eg softer winter/touring tires gives the worst performance with best comfort vs the UHP tires gives the best stopping/acceleration with harder compounds that will give your harsher ride. I went from 21" OEM=>20"=>19" wheels with GLB35 AMG (much stiffer shocks), so 19" wheels feels comfortable enough for me as I can lower the tire pressure to 35/33 with the XL-Extra Load rated Michelin PS A/S 4 tires... I also ordered a spare tire as all my tires are non RF and repair glue wasn't even in the car when I bought it.
Wider width 255 tires should help you to stop/accelerate quickly (if brakes are not at the limit) and will reflect road conditions more on the car (more noise, less comfort). However narrower width 235 tires will give better performance in wet and snowy conditions and might have better ride. So choose your best bet. There is no perfect tire, so choose one depending on your needs. Definitely I would go for CrossClimate2 AW tires for snow performance with softer ride. They are very similar to the Michelin Pilot Alpin 5 winter tires that I use, only lags in wet performance compared to winter tires. In dry/wet performance Michelin Pilot A/S 4 or alternative Conti DWS06+ will give you the best results and lags in snow performance. Michelin Primacy Tour will give middle results which I used it previously also and was satisfied with its performance/comfort with Subaru Forrester XT in driving in heavy snow/rain storms in NY/DC. Also Michelin let you swap tires if you are not happy with them. If you use a local tire shop, it might be easier to test them in your local road conditions.
Old Apr 19, 2023 | 11:30 AM
kgzero's Avatar
2022 GLB250
Thank you for this!
Old Apr 19, 2023 | 02:58 PM
SRNH's Avatar
Serhan, Thanks for the information. Many years ago, I got hooked on the Michelin Defenders with their nice deep tread design, very good in snow and pooling water (no hydroplaning) with those on. Used them on my Lexus RX300 for many-many years, not loud either, good mileage. My biggest problem with the GLB, that Tire is limited in sizes, so the hunt is on. The GLB Tire size is 235/55-R-18, the closest I can get with the Defender is 255/55/R-18. I’ll take a look through the information you provided.
Run Flat tires - The GLB ride is a tad-bit stiff for me, many say the Run Flats attribute to that stiffness so I’m planning the changeover to regular tires with a “Modern Spare” tucked behind the Driver's seat.
2019-2023 Mercedes GLB Spare Tire Kits. Alloy, Compact | Modern Spare
