GLB Class (X247) Produced 2020 to Present
Ethanol free?
Old Aug 22, 2023 | 07:58 AM
Lindagail's Avatar
GLB35 AMG 2021
Ethanol free?
How many of you use ethanol-free premium gas? My husband says his Miata has more pep at low speeds with the 91 grade. That’s identified as premium, isnt it?
Old Aug 23, 2023 | 01:49 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Where do you get it?
Old Aug 23, 2023 | 06:03 AM
ygmn's Avatar
2015 E400 Sedan
91 is premium in Denver I think but where I live 93 is premium and 89-91 is midgrade
87 is regular.
I can only find regular ethanol free
yes more energy per gallon then any gas mixed with ethanol but I doubt one could feel it.
plus better mpg w/ethanol in fuel.
the Placebo effect is a powerful thing
Old Aug 23, 2023 | 07:31 AM
PEagle's Avatar
2010 E550(S212), 2006 Chrysler Crossfire (SLK 320 R170 in disguise), 2012 CLS500 (x218)
Shouldn't it be the other way around and better mpg w/o ethanol as ethanol has a lower energy density?
Old Aug 23, 2023 | 07:47 AM
Lindagail's Avatar
GLB35 AMG 2021
Bucee’s has 93 and a few others around have 91
Old Aug 23, 2023 | 07:48 AM
Lindagail's Avatar
GLB35 AMG 2021
Yes, Miata drivers are big one “the feel.”
Old Aug 23, 2023 | 08:27 AM
hyperion667's Avatar
2012 CLS63
I recall reading somewhere ethanol is bad for engines....which is why (probably) 'they' sell it to us Americans?
Old Aug 23, 2023 | 09:01 AM
PEagle's Avatar
From what I read and discussed, it's bad for old engines because it would dry rubber hoses that weren't thought for it. Other issues are that ethanol "cleans" your tank and so it will remove all the dirt in your tank and may plug your filter/injectors. It's also harder on fuel pump and may require bigger injectors as you need more fuel than with ethanol free fuel.
iirc, most of vehicules from 2000 on poses no threat, especially if diluted in "standard" gasoline.
Another issue is that ethanol captures water so if you have water, condensation or high humidity, ethanol will combine with it and sink to the bottom of the tank. That mixture is much less flamable and will have a hard time in your engine... and as it's sinking it'll be happening on startup.
I may miss other stuff but that's what I could gather from my own research.
Old Aug 23, 2023 | 12:50 PM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
Ethanol or not the Octane number is what dictates how gasoline typically performs aka at what pressure it will self combust. The actual mixture could be different gas station to gas station. We had constant issues with Kawasaki utility vehicles, that kept braking due to cheap plastic fuel pumps effected by ethanol in the gas. As others said modern cars designed for it.
Old Aug 23, 2023 | 05:47 PM
MnewB22's Avatar
GLB 35 AMG
Correct. Under the same octane rating, ethanol gas has lower energy compared to non-ethanol. 93 octane ethanol gas will give better performance than 91 octane non-ethanol. The problem is that ethanol is hygroscopic. Also , ethanol accelerates oxidation of the fuel. This results in reduced volatility and therefore reduces performance and mileage. Keeping the tank at least half full helps mitigate the downsides of using ethanol gas, particularly during cold wintertime.
Old Aug 23, 2023 | 06:36 PM
PEagle's Avatar
I don't know for you in the US but here in France, petrol company pretty much does that for US. Ethanol fuel is named E85 and is at max 85% Ethanol. They will vary the ratio of Gasoline and ethanol depending on the season to avoid hard startups in the winter.
But yes, cold startup is the worst as well as startups after a long period of non driving.
Old Aug 23, 2023 | 06:38 PM
In US ethanol is limited to 10% of the mixture.
Old Aug 23, 2023 | 06:41 PM
PEagle's Avatar
You don't have a specific ethanol fuel?
We have SP95 E10 that's 10% max all non specified (SP95 and SP98) are 5% max and E85.
Note: measures are made differently for octane rating in here so 98 EU is about 91-93 US.
Old Aug 23, 2023 | 07:19 PM
I do not believe US has different % of ethanol. I think it's all 10% as mandated by Federal government. And all gasoline rated by Octane number. We typically only get 3 grades, regular 87, midgrade 89, and premium 93. However on a rare occasion some gas stations have 92 or 94 octane gasoline.
Old Aug 23, 2023 | 08:31 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
Ethanol increases octane and reduces knock and temperature which is good for high compression engines:
Miata has a naturally aspirated engine with lower compression ratios eg 1.6l engine makes 115hp and 1.8l engine makes 128hp.
Old Aug 24, 2023 | 12:23 PM
Odd Piggy's Avatar
I’m not sure about its availability everywhere in the US, but 85% ethanol E85, sometimes referred to as gasohol, is available in SE Texas. The U.S. rules state that it must be made from agricultural sources as a renewable fuel, even though ethanol can be easily and cheaply made from natural gas. Not all locations sell it. However, cars that use it must be rated “flex-fuel.” Typical octane ratings for gasoline here are 87, 89, 93. The octane of gasohol is not stated. Years ago, I bought a used E320 that was built to SA specs and the owners manual said blends of up to 90% ethanol were okay.
A refining engineer I know says that the government mandate on 10% ethanol in gasoline has been dropped, but EtOH as it’s called, is an excellent inexpensive and low toxicity antiknock additive at about 7%, so it probably will never go away.
I suspect most people on this forum know this: The U.S. stated octane rating is determined by adding the research octane (calculated) and the motor octane (measured) and divided by 2. Some companies state (R+M)/2 on their pumps.
Old Aug 25, 2023 | 02:20 AM
PEagle's Avatar
OK, I now know where the difference is from. in Europe we only use the RON as far as I understand which explains why there is this discrepancy between "octane" ratings between our fuel.
However, from what I could find it's not as much as a calculated vs measured but different test conditions that will set RON (idle and acceleration) and MON (full throttle). At least according to articles such as this one.
Around here, some people go with E85/gasohol without any conversion on some engines and apparently without issue. It's the case with the M112 in the Crossfire (R170 SLK320) and they often go with 50-80% ethanol without any other consideration and from what I read, most of them have no issue other than rough start in the cold and lower MPG.
Edit: For anyone interested, I found this article which sums it up pretty well imo.
Old Aug 25, 2023 | 02:54 AM
Odd Piggy's Avatar
Thanks for the info. And on the issue of using E85, my old E320 in fact had an M112 engine. So maybe they were all built to handle high ethanol content fuels.
