GLB Class (X247) Produced 2020 to Present
Oil change frequency?
Old Dec 10, 2023 | 01:22 PM
thomearl's Avatar
GLB250
Hello, new here as I bought a certified GLB250 couple months ago with 20k miles. Browsing the posts it seems that I only need to change oil every 10k miles or 1 year, I guess whichever comes first. Is that correct? If so, can someone explain how that’s possible? I’ve owned about 10 cars in my lifetime and every one of them advised changing oil every 5k or so as the most basic maintenance. Has MB figured out something that no other manufacturer has? Also asking cause the service docs that they provide give very little info. Thx.
Old Dec 10, 2023 | 10:03 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
Yes, oil change is every 10K or yearly. You can check the maintenance service sheet posted below:
https://mbworld.org/forums/glb-class...ice-sheet.html
Old Dec 10, 2023 | 11:22 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
FYI -The service sheet is attached to post no. 1 in that thread noted by @Serhan[size=33px]Also, if you service the GLB yourself be sure to use a low ash synthetic engine oil specifically labeled:[/size]
Mercedes Approval 229.51
Mercedes Approval 229.52
Mercedes Approval 229.61 or
Mercedes Approval 229.71.
Statements like “meets Mercedes specs” are not approved oils.
Old Dec 10, 2023 | 11:46 PM
thomearl's Avatar
GLB250
Thanks. Still under warranty, so will be taking to dealer.
Old Dec 12, 2023 | 03:32 PM
tbirdvet's Avatar
GLK350
Older oils require more frequent changes but new Synthetics not so much.
