GLB Class (X247) Produced 2020 to Present
Sending directions from phone to car.
Old Aug 19, 2024 | 07:01 PM
KesK's Avatar
GLB250
How do I fix this ? Also this is my first time using such a forum. Be nice I searched on google and othe threads but didn’t find anything helpful.
Old Aug 20, 2024 | 04:16 AM
DESAL's Avatar
GLC SUV 350e Verde Silver Metallic
Can you be a little more descriptive. What are you trying to do? What phone are you using? I’m on vacation and wouldn’t be back in my GLC for a few weeks, but the my iPhone will respond to carplay and the MB MBUX system has any number of responses? The iPhone will respond to Siri questions but not phone control commands like turn up my AC. That’s a MBUX command. The phone works well with any map apps Google, Apple, Waze. Also something both phone and MBUX need the built in WiFi which I don’t describe too.
Old Aug 20, 2024 | 07:36 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I think Send to Vehicle works if Navigation is currently enabled in the GLB. Are the normal NAV functions working properly? If so, a call to the dealer or to the MBCA Mercedes Me number may be in order.
Old Aug 20, 2024 | 07:38 AM
W205C43PFL's Avatar
Try logging in the Mercedes Me Connect portal and see if things are activated properly.
Old Aug 20, 2024 | 08:48 AM
KesK's Avatar
GLB250
yes I paid for the navigation package and from the Me Portal everything is activated. The navigation works, except the search is very limited. But I know I should be able to send. (I tried with my wife’s phone also, so I don’t think it’s a phone issue, using an iPhone. I know how to connect and use the apps from the phone google maps etc. but that requires a usb wire. Maybe I’ll just call the firm, i thought it would have been a simple fix.
Old Aug 20, 2024 | 08:51 AM
W205C43PFL's Avatar
You could also drop by your local dealership and ask your delivery specialist for assistance, since they were responsible of setting all this up for you in the first place.
Old Aug 20, 2024 | 02:29 PM
mikapen's Avatar
Yes, it does sound like you need to get the dealer involved.
Old Aug 20, 2024 | 06:10 PM
superswiss's Avatar
2019 C63CS
It is not clear which Mercedes me connect service this is tied to. I don't see a specific service for this, so it must be tied to other navigation services, but if they are all enabled for your car, then I'm not sure why it would say it isn't activated. The one thing I had to do in my car was to authorize the Mercedes me connect app. After pairing the phone via Bluetooth, the COMAND system (I don't have MBUX) detected the Mercedes me connect app on my phone and prompted me if I wanted to authorize it. I'm assuming this step is necessary to receive destinations sent from the phone. Did you get such a prompt? I'm not sure if this is still necessary with MBUX.
Sending destinations to the car works in two ways. If you are away from your car, then the destination is sent over the Internet via the car's data connection. However, if you are already in the car and your phone has an active BT connection, then the destination is sent over BT directly to the car. Do you get the same message in both cases? I never had to activate anything special. I just activated all the Mercedes me services I was subscribed to, and then as mentioned authorized the Mercedes me connect app after being prompted by COMAND. It's worked ever since, outside of the occasional outage, but I was always able to send destinations at least via BT when inside the car, even if there was a Mercedes me connect outage at the moment.
Old Aug 21, 2024 | 11:54 AM
DESAL's Avatar
Your screenshot didn’t show the 1st time I saw your post. But I too agree drop into the dealership. Canada and the US might have different specs.
