Noise from dash
#51
I am hearing a coil spring squeak when i go to a speed bump. it's on the right side compartment. I attached my recording, first occurence happens on 4-5 sec mark then more clear is on 18 sec mark. just in case you guys can't access the file here's the link:
https://onedrive.live.com/redir?resi...int=file%2cm4a
ay55 (04-07-2016)
maylin (04-14-2016)
#54
I was told that the replacement struts are the same and therefore the risk of noise will still be there. Assume this is true. They said they will call me when the new strut is available.
#56
Mine started to have quite similar dash/front driver strut old door like noise , on speed humps or slight road imperfections. Booked in dealer next month but will try to see it can be earlier without loan car.
Normal suspension, 7000km on the dash.
#57
Same here. Noise started about a month ago at 4000 km. The dealer said they would need to reach out to engineers in Germany, finally called today to make an appointment for two days.
For people who have had the struts replaced, do you know if this is a case of bad batch of parts or a more generic design issue ? I am afraid if they just replace with the same thing, the issue will keep coming back.
#58
Went to the dealer twice with this no help. Even the loner had the same thing.
Could not deal with a new car having wheels vibration and reverberation feeling in steering wheel. Then the dealer looking at you like you have two heads.
So Today I fixed my problem myself.
I bought the 2017 Macan S.
Got a good deal on trade. I paid 49k for MB they gave me 47k . Lucky me
Good luck to all I hope they find a fix.
#59
Wassaby (08-28-2016)
#62
much overdue update: after the "special German lubrication" exact words from the service department. The noise is gone although when i look up into the front right wheel well i can clearly see a white paste like substance on the strut and its surrounding areas. The strut has not been replaced and the car drives fine (just finished a 4000+km road trip half way across the country) but it's still a little unsettling.
#63
How is your car now after the fix, also which dealer did you go to? I have the same issue after 800km.
Ziggy_CDN (08-31-2016)
#64
again...
After the previous fix over 1 year ago, my car is making the squeak noise again when get over bumps.
Have any of you experienced the same? What was your remedy?
