GLC43 front camera
GLC43 front camera
Hi guys,
A new proud owner of a GLC43. Nice to be in the family![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I have a question, since I got a car which was in stock so I didn't have to wait, I don't have the 360 degree camera system which I wanted. Is is possible to install after market parts?
Any recommendations?
Thanks!
Thanks!
Replicating the 360 surround view system will be very difficult but adding front view cam should be pretty straightforward. The camera install will be easy. The tricky part is figuring out how to get command to recognize and display the image at the proper speed.
Check Mid-City Engineering as one source for multi-video input adapter that can be installed behind COMAND - then a front camera gets added - then you switch back-n-forth - there is a hack I "think" that can give you video-in-motion..
Google Moving-On-Sounds in NY as a reputable aftermarket source
Mr. J (01-06-2017)
check this!
http://naviks.com/cart.html
