Sport plus on the GLC43
(1) anyone got tips on how to get the best Crackle and pop sounds? Keeping my revs low for the first thousand miles
(2) today put my car in sport plus while driving slowly around a 90 degree corner (15mph not accelerating) and car juddered fairly violently as if it was a stick shift about to stall. Anyone else experienced this? My takeaway was note to self - do not use sport plus unless you genuinely intend to drive fast. Only happens in sport plus.
1. Easiest way to get the crackling sounds is to decelerate fast or just rev the engine whist in sport or sport+ mode. Tends to be easier when the engine is still cold.
2. Sport+ is not meant for slow easy driving. I had the same thing happen on a BMW 645Ci with an SMG gearbox.
https://mbworld.org/forums/glc-class...full-lock.html
Could this be a rare LHD version of this problem?
Use manual mode and downshift into 2nd when cruising on surface streets. Goose the throttle and then immediately let off. The overrun will produce the crackle on demand and in 2nd gear will provide the loudest and most pronounced crackle.
I questioned that in my mind when they told me that, luckily when I will pick it up this Saturday it will only have 60 miles on it so hopefully it wasn't beat too bad in that short period of time. I think I put on 20 of those miles too.
Really, this can't be true can it?
Engine oil
General notes
Depending on your driving style, the vehicle
consumes up to 0.9 US qt (0.8 liters) of oil per
600 miles (1,000 km). The oil consumption
may be higher than this when the vehicle is
new or if you frequently drive at high engine
speeds.
Engine oil
General notes
speeds.
