GLC spare tire options
thanks!
In 2011 I had a BMW with run flats and replaced them with traditional tires and indeed the ride quality was better. Wanted to check if thats the same situation with you folks. Being as I have a leased GLC 300, just wondering if its worth the trouble as we'll barely have 20k on the car at the end of the lease (my wifes is the driver and this GLC will be a true cream puff). If I have to replace the run flats, then new run flats are not crazy expensive.
i have 20k on mine now and the wear is noticeable; i may not even reach 30k which sounds like similar to what others have seen. I have another vehicle with same size 235-60-18 Mastercrafts with 25k miles on them and they look brand- new
Spare wheel 18x4 $314 online oem part # 164-400-00-02
Tire T155/90D18 Tirerack $129.41
Tire valve $5 oem part # 000-400-29-12-64
Wheel Bolts (M14x1.5x26mm) – I bought eEuroparts.com sku 18913. I think oem part# is 0009908307
Tools, including jack, for changing Spare tire, $81.90 oem part # 166-580-69-00
Does your acquired spare tire kit fit in your cargo bay with the cover closed ?
Thnx
Pahunter.
Compact 18X4 Inch Rim Spare Wheel Tire 1644000002 Mercedes ML350 W164 W166 06-15
successfully come up with a 18 inch DOUGHNUT style spare tire that fits into a 2019 US GLC 300 base suv With the deck board closing ? If so. Can you please provide your source and part number/s maybe pictures. Thanks.
I also order shorter bolts for $24 and a complete jack with tools for $36. So $150 for everything. I will report back on whether it all fits and works. I'll definitely do a test tire change using just the items I bought and drive the car to make sure everything will work when it's needed.
https://www.ebay.com/itm/1998-2005-M...72.m2749.l2649
https://www.ebay.com/itm/Five-5-Merc...72.m2749.l2649
https://www.ebay.com/itm/Compact-Don...72.m2749.l2649
Jeff
Just following up. Did you receive your spare kit you ordered and does it fit in your cargo area below floor hatch ? Maybe a few pictures if you were successful.
jeff
Long story short, it all works, I’m happy with it all, but spare only fits on the rear. So if you have a front flat, you put spare on rear first, then rear on front and front in trunk.
There is a bigger spare available but I don’t know if it fits under the floor like the one I got.
