Tire rotation/resetting TPMS
I want to do my own tire rotations on my wife's GLC300. Will the TPMS need to be reset for the new location of each tire or will it know they have been moved automatically? I know on a Dodge Ram 2500, it knows they have been moved. Apparently there is an antenna in each wheel well. Any ideas on the GLC?
If you are in the USA. TPMS is based in each wheel. Need to set wheel to appropriate pressure once rotated. I would go ahead and reset system.
I understand the question. Antennae are at each wheel on cars in USA with sensor mounted in the valve stem. If you keep pressure the same in all 4 wheels you do not need to do anything. If you use different pressures front and rear. I would get pressure where you want it for each tire after rotate and reset system. Cars in Canada read off ABS. I do not know about the EU or GB.
Awesome ! Thanks guys for the input! Glad to know I can rotate tires myself without a trip to the dealer to have sensors reprogrammed! Vehicles keep getting more and more complicated for good ole boys to be able to do their own maintenance.
Now I get it. Thanks.
For GLC that comes with TPM system that reads off the ABS, are there any settings that can be set for them? Eg sensitivity or alert threshold?
If we do get a warning, after getting the affected wheel fixed, do we need to reset it in anyway or just start driving it as usual?
It's in the menus, using the buttons and arrows on the steering wheel.
vratenza (04-27-2017)
Anyone know how to reset the system after rotating tires for USA models? To be more specific, I see how there is a simple reset function if the tires are set to a new pressure for example. But, how are they "re-programmed" once they move to different corners of the car?
Thanks!
Thanks!
In this case, "reset" doesn't give the desired results in the index. Neither does "restarting" but that is what it is actually called once you read every page that could be related.
Thanks for not helping!
Of course I tried, why would I make a post otherwise? This isn't my first rodeo and I've been working on cars for many years (but not MBs). Looking at the manual index is of no use in many cases. You have to read every damn page. MB just makes it way harder to find than every other car I've owned. Maybe its a language-translation issue that aggravates finding the terms to look for.
As far as I know this isn't documented,
Xguy (12-04-2020)
