OEM Roof Rails for Coupe - beware
https://www.rackattack.com/car-rack-...enz/glc-class/
The crossbars attach to the factory side rails on the GLC SUV. Unfortunately, the GLC Coupe doesn't have side rails. You will need to talk to them about which feet to use to mount the bars on the Coupe's fixed mounting points, and you will need to consider if they will interfere with your pano roof as a result.
Both the MB pieces and the Thule pieces come with a warning that they may interfere with the pano roof. This may be the case if you mount things that point downward and protrude below the bars. If you mount things that simply strap to the bars and don't protrude, you can use your roof just fine.
I have a set of Atera Signo aero bars with a Kamei box on top with t-tracks. They work really well but the roof catches in the bar clamps if you try to open it. As I use it for skiing, not a big issue for me.
In my coupe there's something weird going on. When I push the sunroof open button, it stops a bit short of opening all the way. When I open it all the way, the wind noise becomes MUCH worse
Wind noise and buffeting are not too bad if the roof is in this position. Manually opening the roof beyond this point will result in excessive wind noise and/or the dreaded thump-thump buffeting in your ears.
You can try opening both rear windows about 2 inches. If that doesn't solve the problem, try using the comfort position if you're going to be going above 35-40 MPH.
Those are the same Thule (model 7601a/7601b) crossbars that I purchased. The design is slicker and much more aero than the MB bars. Hopefully you were able to return the MB pieces.
