opening windows with the remote from the outside
2018 GLC300 P01 selenite grey
I used to be able to open the 4 windows in my 2018GLC with the remote, by pushing twice the open button on the remote, and holding the button depressed the second time.
I tried it again yesterday and now it doesn't work...I must be doing something wrong.
This feature is not discussed in the user's manual, but it seems to be standard with most German cars.
Anyone has been able to open the windows from outside with the remote?
Press and hold the Unlock button on the FIRST push and it should work. Don’t think doing that on a “second” push is necessary.
In in case you didn’t know, pressing and holding the Lock button will close all the windows (and the Pano too if it’s open). Again, press and hold on the FIRST push.
Yes, you have to be super, super close -- a really stupid trait to the whole function. You should be able to roll your windows down/up as far as the remote works (like my Lexus and Acura had it)... a wonderful feature to air your car out on a very hot 100+ degree summer day!!
Another cool feature -- if you're exiting the car and realize one window is slightly open, you can hold the lock button on the exterior door handle and the windows will also close.
So, went and messed around with this in the garage a bit, so didn't get to test distance, but the way MB has set up this function is still frustrating. IF you have a Pano roof and the sunshade is closed, it still seems like you have to do a 2-step process. Push open and hold on keyfob once which unlocks everything and then opens the sunshade, then press open/hold again and the windows, sunroof, seat ventilation opens/comes on. I tried holding the open button on the keyfob and it doesn't work as a 1 step, if the sunroof sunshade is closed. Can someone else that has a Pano confirm this? Stupid implementation by MB, if so. I will say it is neat to just hold the button on the door handle to close everything up, but that may get used 1% of the time. Opening everything up on a hot day, easily and from a decent distance, is the more necessary function.
Ok, that worked, when real close to the car. (I don't have a pano roof).
I think it used to work at a better range a year ago. Maybe the battery is getting weak now?
I'm not sure if this is still the case, but older MB used two signals infrared and radio. The radio frequency locked/unlocked, and the infrared did the window functions. If that's till the case today, it may be the reason why you have to be close -- infrared works at shorter ranges ... but I don't see those little black infrared receivers embedded into the handles like the older MB had. I dunno.
Anyone know of any hacks/ tricks to get it to work from greater distances? My Infiniti would work from about 50 feet away. Its kinda useless to only be able to vent the car when you are almost close enough to get inside already
Maybe someone will let us know if Mercedes me is more reliable lately.
Luke is spot on here as well; because of that infrastructure, not only is a close distance needed, line-of-sight is also required for the advanced features. For best operation the cycle should be performed while pointing the key fob at the driver door of the vehicle. If you know how to do it and when it can best be utilized, sure it's neat - but it could be way better, and needs to be much better moving forward.
Of course you could always use the Remote Start function in the Mercedes me app to cool your car down.....if it would actually work when you wanted to use it. I tried it in my driveway once and thought “cool”. Then the few times I tried to use it while out and about, the Mercedes me app was either down or it “thought” I had less than 5 gallons of gas and wouldn’t remote start it. Really? It only runs like 10 minutes on remote start. That’s a little too much nanny state for me. I lost interest and have never tried to use it again.
Oh, and it's now free for 3 years, not 5.
Pano roof and sunshade operate separately. Each requires a separate button push to fully open or fully close. This is true from inside the car and it works the same from outside.
- If everything is open on mine, and I press/hold the lock button, windows and sunroof close but shade does not. Shade requires a second press/hold/, same as it does when I'm inside.
- If everything is closed and I press/hold the unlock button, windows and shade open but sunroof does not. Roof opening requires a second press/hold on mine. Again, same as it does when I'm inside.
Mercedes-Ben GLC300 4Matic
Is the MercedesMe Connect App available on the GLC for 2019? or just some of the 2019 MB's? Looks like it does a lot more than the me App, im guessing us old timers are out of luck?
As far as the exiting MercedesMe app, when i first got the vehicle i will say it was maybe 65% or so good at starting, maybe a little more. now just over a year later i will say it works right almost all of the time, though once in a while it does miss.
yes and the 5 gallon limit on a such a small tank is crazy.
