2018 glc 300 tpms does not show pressure numbers?
Old 09-20-2018, 08:21 PM
Glc318's Avatar
Glc 300
Just wondering if the pressure number show anywhere? Run flat indicator has come on, but it won’t show me which specific tire or the tirepressures of any tires, I had old gmc 2009 that had this feature? Am I overlooking it or does it not come with the vehicle?
Old 09-20-2018, 08:23 PM
protseng's Avatar
2019 GLC300 SUV
suv model doesnt have tpms, but the glc coupe with sport package does.
Old 09-20-2018, 08:54 PM
openwheelracing's Avatar
GLC
My 2018 GLC SUV has the numbers.
Old 09-20-2018, 09:42 PM
Glc318's Avatar
Glc 300
hmm which model is yours it, mine is a 2018 Glc 300 with prem plus/ sport packages if it doesn’t have tpms how does it monitor when my pressure is low?
Old 09-20-2018, 10:31 PM
GLC
Mine is just the typical GLC300 in US. They all have TPMS. I don't know any new car without TPMS these days, let along a Mercedes.
Old 09-20-2018, 11:11 PM
Glc318's Avatar
Glc 300
I’m in Canada, I tried to find the numbers, but can only see it says one of the tires is low. Yeah my 2009 Sierra GMC has this feature can’t beleive at 50g car in 2018 doesn’t.i mean it tells me a tires lows, “run flat indicator” so shudnt be that hard to process a digit? Do you mind telling me where you found it?
Old 09-21-2018, 06:41 AM
decorily's Avatar
GLC 300d 4matic
I believe there are 2 completely different systems for monitoring tyre pressure.
One has pressure sensors in each wheel (attached to inside of valve) which relay actual pressure to the onboard system while the other system doesn't monitor actual pressure but uses the ABS (braking system ) sensors to compare wheel rotations and figure if a tyre is under inflated.
Old 09-21-2018, 10:37 AM
guhvies's Avatar
2017 C43 AMG Saloon
Then it looks like the Canadian GLCs don't have tpms.
Old 09-21-2018, 12:40 PM
decorily's Avatar
GLC 300d 4matic
Not sure why you say that... I expect they have one or other of the systems I mention above.
Old 09-21-2018, 10:15 PM
Tylbran's Avatar
2018 GLC 43 & 2014 SLK 350, gone 2016 E63 Wagon
My 2018 GLC43 shows the tire pressure as well as a warning light. As a minimum I believe all vehicles are required to have a low pressure warning but not necessarily a system that shows actual pressure.
Old 09-22-2018, 08:41 AM
guhvies's Avatar
2017 C43 AMG Saloon
Because all the Canadian posters in this thread don't have tpms on their vehicles. The USAins do but their vehicles
have a different spec.
HTH
Old 09-23-2018, 01:27 PM
PickyBoy's Avatar
GLC300 2018
For the Canadians: to have the numbers you need to have the sport package or a 43 etc... otherwise the detection of a low pressure tire is done using the difference on the rotation between the two front or rear tires (something like that )
For US: you're lucky, you all have the numbers
Old 10-05-2018, 05:57 PM
scotchy's Avatar
I think only 2018's have it. (I'm in Canada too.) My 2017 GLC43 doesn't, just the warning, and you have to figure out which wheel it is on your own. Crappy system, my last BMW was the same, it can need to be out by more than 5psi it seems to trigger it.
Old 10-06-2018, 08:38 AM
Citizen613's Avatar
MB GLC250
As far as I know, TPMS is dependant on country and model.
If not mandated by local laws, it was up to the local importer as to the fitment of the true TPMS with pressure sensors in each wheel and hence dashboard display for each wheel.
Some importers chose to not have this fitted if it was not standard factory specification. Just part of the complicated pricing deals with the factory.
Here in Australia the MY 2016 GLC did not get TPMS …..I think 2017 as well ..and the latest model..I think.
Yep ...just looked up our local Brochure specifications ...no TPMS on the wagon until you select the AMG43 ..and up.
Like Canada ..the Aus ...Coupe versions get the full TPMS
….which makes it all very confusing.
Quick Reply: 2018 glc 300 tpms does not show pressure numbers?
